Battery Will Not Charge - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Battery Will Not Charge (/thread-5189.html) |
- walk10 - 06-20-2020 Hi I have a constant battery warning on my keypad and I have tested my battery and it is very low. I bought a new battery and very soon had the same problem. When looking closely at the LP51 and LP52 bulbs they appear to have blown. Is it possible to get replacement bulbs? I am able to solder them on if I could get new ones. Any help is much appreciated. Thanks Dave - slychiu - 06-21-2020 Replace the bulb with a Resetable fuse, You can buy from Farnell https://uk.farnell.com/littelfuse/rxef030/polyswitch-radial-0-3a/dp/1175861?st=rxef030 Just solder it to one of the LP51 or LP52 as they are in parallel This will protect the battery from overcharging but will not burn up |
