UCM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: UCM Problems (https://www.comfortforums.com/forum-73.html) +---- Thread: UCM (/thread-5193.html) |
- slychiu - 12-30-2020 Does it work after reset? what is the Comfort Firmware version? - slychiu - 12-30-2020 Also please check that the UCMs red and green leds are flashing, and you can see the IP address in Comfort Server Manager - raygregg114 - 12-30-2020 All is ok now.Looks like when i updated comfigurator from 3.13.5 to 3.13.6 it changed the IP settings to DHCP which i had set as static, also removed the network local from settings and changed to WIFI. once i set this back and put the IP address back in all worked fine.Thanks as always for your help. - carlford - 01-14-2021 Greetings to you slychiu. It\'s been awhile. I am in need of an obsolete UCM01. My old comfort1 is still kicking but i lost my last reserve of my ucm01\'s. I was hoping that some of your distributors might have some NOS lying around. MY last UCM01 has a burnt spot on the back side of the board and probably makes it non repairable. If any of your installers or representatives that have some old pulls would be OK also. No problem sending them the $$ and doesn\'t have to be in a hurry as I just installed my last backup and am up and running again for now. If you think of a distributor that carries his own inventory maybe they have an old board lying around. If you feel this message is not appropriate due to the obsolescence of the ucm01 then feel free to delete as you see fit. Thank You for looking. Respectfully, Carl Ford - slychiu - 01-15-2021 hi Carl Good to hear from you. I hope some of our old customers have an old UCM01 for you. The last UCM01 was manufactured more than 20 years agio - Home - 01-15-2021 Yes I have one available Do you need any other obsolete Comfort parts as we do keep a stock of a number of old items. Have many C1 boards and quite a few doorphone parts inc replacement speakers - ninotorres - 03-07-2021 Out of nowhere I also start having this issue.I tried everything discussed here besides changing the UCM itself and the error is still there.I can connect to the Comfort using the USB/UCM.Using that connection I just upgraded every firmware available.Still having the error. This is very annoying. - slychiu - 03-08-2021 Plrease gove more info. I this is UCM/ETH03?Is the ID correctly set? and diffrebt from other UCMs? Are the D9 and D10 Leds both blinking? Was this ucm working before? take a photo os the UCN - ninotorres - 03-08-2021 Hello slychiu. It\'s a UCM/Eth02.LEDs seem ok, blinking as expected.It was working until some weeks ago (last time I have evidence of correct behaviour) Now, there is something that I feel is awkward.I have reused a Python script from an MQTT integration found on the web to test the connection. (found here).It\'s connecting successfully. So, can this be a Comfigurator issue? I\'m running Version 3.13.6.0 as the previous user ...I would test with a previous version, but not sure exactly which one would produce any results. Were there any significant changes on the way Comfigurator connects to UCM that you are aware of in last versions? Thanks,Nino - slychiu - 03-08-2021 No changes in Comfiguratir that would affect eth02. If you have a working UCM/USB, can you swap the UCM baseboard with the plug in ETH02 and USB So we can confirm if the UETj02 or the UCM baseboard that causes the problem |
