Date and Time Synchronisation by UCM/ETH03 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Thread: Date and Time Synchronisation by UCM/ETH03 (/thread-5464.html) |
- slychiu - 01-13-2024 SNTP Setting ![]() Check that the local time is correct. Select one of the servers in the NTP Server Pool. These are a list of International NTP servers that provide the local time adjusted for Daylight saving where applicable The NTP Synchronize Interval is the interval for the updating of time to Comfort. 60 minutes is the recommended interval athough you can set a shorter time for testing. If the time difference is less than 4 seconds, the Comfort time is updated but is not recorded in the event log. \"Send Time to Comfort\" should be checked if the time should be sent to Comfort. Leave it unchecked if you do not want to update Comfort Time. Comfort will correct for any Daylight saving Time adjustments based on the Sunrise/Sunset times settings so it is important to get the setting to the correct location. |
