Comfort panel dead, no leds - Printable Version
+--- Thread: Comfort panel dead, no leds (/thread-5842.html)
Comfort panel dead, no leds - wexfordman - 04-06-2026
Had a decorator in, and while painting he removed a pir to get behind it (the wall was being dry lined).
Anyway, next day I noticed comfort was down, naturally I went to.check the removed pir,.to.find that.several.wires.were shorted including the dc and ground.
Removed.rhe shorted powered off.comfort,.disconnected the batter for about 10 mins and then brought everything back up.
Comfort failed to start.
Any ideas what.i am ooking.at here ?
RE: Comfort panel dead, no leds - slychiu - 04-06-2026
remove all exyternal wires from Comfort, then turn on the power, dont connect battery at this poimnt. chevk iff comfort satarts by looking ath the leds. fgreen led should be blinking.
Then connect the keyupad, thgen other zione wiere4s and chefvk at which point comfort stops woring
RE: Comfort panel dead, no leds - wexfordman - 04-06-2026
(04-06-2026, 08:25 AM)slychiu Wrote: remove all exyternal wires from Comfort, then turn on the power, dont connect battery at this poimnt. chevk iff comfort satarts by looking ath the leds. fgreen led should be blinking.
Thanks, will be next weekend before I get to look at it, will update with results
