Alarm Control Via C-Bus
Hi All My First post Here. Just Got The Comfort / minder And Have Hooked up C-Bus Correctly But Have no Knolwedge of Programing The Comfort. Apart From Setting up the Zone Types And Getting A C-Bus Group Adress To Switch ON Away Mode. But i Cannot Set the Alarm To Security Off. the Only Way is through the Telephnone.
What im looking for To Start off With is A Simple 8 Zone Alarm input With A C-Bus GA For Away, Night And Security Off . Any Help or Advice Welcome. im Walking Around Like A Bear With a Sore Head. The reson For The Comfort is i Had A Minder MK 2 ( AKA Thinkboxx Panel For 5 Years ) Worked Fine the Lightning!!i Bought the Comfort Through Clipsal S.Africa And they Have no Training, No Manuals No nothing i Have Read The cbusman.pdf. my Experience With The Old Mk2 Minder Was Great ( Logic And All) So im Starting At the Bottom With This one.Big Grin Hence The Questions.
Thanks Have A Comfort able Day, Clinton
Welcome to the Comfort forum. I am sorry that you did not get any training or documentation from Clipsal
You can find all the manuals, and technical documentation that you need on the Cytech website  https://www.cytech.biz/
The Product Information page
https://www.cytech.biz/Default.aspx?cmd=...LjokO7E%3d  has links to Products and Downloads including Manuals, Brochures, Training, Software, Technical Information etc
We believe Comfort is the most documented product in the industry
The logic programming capabilities are very comprehensive and will be as good as what most people have encountered
Regarding your specific questions
It is easy to use a Group adress to arm to Away, Night, Day mode or to disarm, although I would not recommend you to allow someone to disarm a security system by a touch of a button. The Comfort keypad should be used to disarm the security system by entering the user code.
To illustrate, the file cbusdemo1.ccl has assigned Cbus group addresses 4,5,6 to arm to Away, Night and disarm to Security Off Respectively
Look at Events > Counters and look at the Responses assigned to Counters 4,5, and 6. I have assigned standard Responses to Arm to Away, Night mode to the counters
C-Bus sends commands to Comfort via Counters. a Counter number corresponding to the group address receives the value eg 255 for on, 0 for Off and 1 to 254 for a dimming level. The Counter Response is activated when the C-Bus message is received
Comfort supports the C-Bus Security Application. The C-Touch touchscreen is able to show the state of the security zones, alarm, states and armed/disarmed status. The keypad can be emulated on the screen so that you can enter the user code in order to disarm the security system
.ccl   cbusdemo1.ccl (Size: 81.85 KB / Downloads: 24)
Hi there Tahnks for The Reply
The Disarm Feature is on A C Touch Clipsal Touch Screeen password Protected Page. Has Worked Fine for Years. How Do i Disarm Via C-Bus i Can Arm Via GA in Counters But Cant Find the Disarm Or Security off From Drop Down Box. ( Ps Have Read Most Of Docs Reading Aint So Good nomore Getting old Er ..
Thanks For the Promt Reply.
thanks, Clinton
The Disarm Response is programmed in Counter 6 Response in attachment in my previous post, as I mentioned . Download the cbusdemo1.ccl file and run it
regards
Hi there im unsing Mind IT Software, Maybe im not All There But under Counter 6 i Dont Have the Disarm Feature. Thanks For the Cbus demo File It Will Probably Help Me out Alot But If i use Yur Demo File And Rename it And Change it To my Group Adresses I Havenet Acheaved Any Thing except Having Some one Get the File For Me.. How Did You Do it? Or Should i use Comfigurator?. if So i need to Change the Word Lsit To English Residential Coz the File Attached Said usae the Eng File if You Have Minder Pro. Hope This All makes sense To You.??Cool
Make sure you use the attached file cbusdemo1.ccl in the previous post
See the screenshot below of the Counters page where you can see the Response Disarm under Counter 6. You should be able to see the same thing
Disarm is a new Response that I had created to show you how this is done
You can use this as an example of how to program such a requirement
I suggest that you use Comfigurator 2.2.3 (donwload from (https://www.cytech.biz/softwate.html )which is the latest version rather than Mindit which you may not have the latest version of
The programming of the Disarm Response is shown
[user=1]Thanks. A Million Your help Has Got M A Working Alarm Panel that i Can Arm / Disarm. This Week i Will play With The C- Bus Functions, Thanks And Have A Great Day.....Big GrinBig GrinBig Grin
[/user]
