03-06-2009, 02:42 PM
These are the list of words that have been recorded but used in the Vocabulary. The VoiceProc Software tool can be used to customise the vocabulary
1
10
10th
11
12
13
14
15
15_1
16
16_1
17
18
19
20
2nd
30
3rd
4
40
4th
5
50
5th
6
60
6th
7
70
7th
8
80
8th
9
90
9th
a
abnormal
abort
abort_1
ac
accept
accept_1
access
access_1
accounts
acknowledge
acknowledged
action
action_1
action_2
activate
activation
active
actuator
add
address
add_1
aftertone
after_the_tone
air
aircon
airconditioner
aisle
alarm
alarm_1
alert
alert_1
all
am
amplifier
am_1
analog
and
annex
answering
answering_machine
antenna
apartment
appliance
appliances
april
april_1
aquarium
area
arm
armed
at
attic
august
auto
automatic
automatic_1
auxiliary
av
away
away_mode
away_mode_1
awning
b
baby
babys
back
backup
baggage
balcony
bar
barn
barrier
basement
basement_1
bath
bathroom
battery
beam
bedroom
begin
bell
belt
big
bin
birthday
black
blind
block
blower
blue
board
boil
boiler
boiling
bolt
booster
bottom
box
boys
break
breakdown
breaker
breakfast
breakglass
bright
brightness
building
burner
bus
butlers
button
bypass
c
cabin
cabinet
cable
cage
call
caller
call_1
camera
campus
car
card
care
carer
carpark
carporch
carriage
cartridge
case
casement
cat
cbus
cctv
cd
ceiling
cellar
centre
cer
chairman
chamber
chandelier
change
changing
channel
charger
check
children
chiller
chime
chimney
chute
cinema
circuit
class
clean
cleaner
cleaners
cleaning
clear
climate
cloakroom
clock
close
closet
co2
coat
code
codepad
codes
coffee
coil
cold
comfort
command
common
communication
compartment
compound
compressor
computer
condensation
condense
condenser
conference
confirm
confirmed
conservatory
console
contact
contactor
contactor_1
contactor_2
container
container_1
control
conveyor
conveyor_1
cooker
cooker_1
cooking
cooking_1
cool
coolant
cooler
cooling
copy
corridor
counter
court
crack
cubicle
cupboard
current
curtain
custom
cut
cytech
d
danger
dark
darkness
data
date
daughter
day
daylight
day_mode
db
db_1
dc
december
deck
degrees
dehumidifier
delay
delete
demand
department
description
desk
detected
detection
detector
dew
dial
digital
dim
dimmer
dimming
dining
din_rail
director
directors
disc
discharge
dishwash
dispensary
dispensing
disposal
distribution
dog
door
double
down
downlight
downstairs
drain
drainage
drapes
drawer
drawing
dress
dresser
dressing
drive
driveway
dry
dryer
drying
dsp
duress
dvd
dvr
e
earth
east
eib
eject
electric
electrical
electricity
electronic
elevator
elv
emergency
emission
empty
emsb
end
energy
engine
engineer
engineering
ensuite
enter
entertainment
enter_new_number
enter_new_number_and_hash_key
enter_new_number_and_hash_key_1
enter_new_number_and_pound_key
entrance
entry
environmental
equipment
erase
erased
erection
escalator
event
event_log
exhaust
exit
expansion
external
eye
f
factory
fail
failure
family
family_care
fan
fast
father
fault
faulty
fax
fcu
february
february_1
female
fence
fill
film
filter
finger
fire
fireman
fireplace
first
first_1
fitting
flag
flash
flat
float
flood
floodlight
floodlight_1
floodlight_2
floor
flow
fm200
fob
food
foot
footlight
for
force
forward
for_1
for_door_station
for_engineer_menu
for_home_control
for_messages
for_partitions
for_previous_menu
for_program_menu
for_security_menu
for_voice_station
fountain
foyer
foyer_1
freeze
freezer
friday
front
frost
fuel
full
function
furnace
g
gallery
games
gang
garage
garbage
garden
gas
gas_1
gate
general
generator
genset
girls
glass
goodbye
goodbye_1
green
greeting
greeting_message
grill
ground
group
gsm
guard
guest
gun
gym
h
half
hall
hallway
halon
hand
hangup
hang_up
hash
head
hear
heat
heater
heating
hello
help
hex
hifi
high
higher
high_temp
history
hold
holiday
home
hose
hot
hours
house
housecode
ht
hub
humidifier
humidity
hundred
hvac
hydraulic
hydraulic_1
i
ice
id
idle
immediate
in
incoming
indoor
infrared
inner
input
inside
installer
intake
intercom
interface
internal
internet
intruder
invalid
inverter
is
j
jacuzzi
january
january_1
july
june
k
karaoke
kennel
kettle
key
keyfob
keyless
keypad
keys
kitchen
l
lab
laboratory
lamp
land
landing
landscape
laser
last
latch
latched
laundry
lavatory
lawn
leak
leakage
learn
leave
leave_your_message
left
level
library
lift
light
lights
line
link
listen
living
load
lobby
local
location
lock
loft
log
loop
loud
lounge
louvre
low
lower
lo_temp
lt
luggage
lumber
lutron
m
machine
macro
mahjong
maid
maids
mail
mailbox
mailboxes
main
mains
maintenance
male
manager
managers
march
march_1
marketing
master
maximum
may
may_1
meals
medical
medicine
medicine_1
medium
meeting
meeting_1
melt
melt_1
mens
mens_1
menu
message
messages
meter
meter_1
mezzanine
mezzanine_1
mezzanine_2
mezzanine_3
microphone
middle
minimum
minutes
mobile
mode
modem
module
moisture
monday
monetary
monitoring
month
moon
mother
motion
motor
move
movement
movie
mp3
msb
music
n
name
network
new
new_message
new_messages
next
night
night_mode
no
noise
normal
north
not
november
NUL0.WAV
null
number
numbers
nursery
o
observatory
october
of
off
office
oh
oil
ok
on
open
operate
options
or
out
outdoor
outer
outgoing
output
outside
oven
over
overflow
overheating
overload
override
oxygen
p
pabx
pabx_2
pad
pager
pan
panel
panic
pantry
park
parking
partition
party
pass
passageway
passive
path
patio
pause
pause_1
pcu
pdu
pelmet
pendent
penthouse
perimeter
personnel
pet
phone
pill
pin
pipe
pir
pit
place
plant
play
please
plug
pm
pm_1
point
points
pool
porch
pot
pound
pounds
powder
power
pre
preaction
preactivation
precision
press
pressure
previous
print
printer
private
program
programming
projector
protect
protected
protection
public
pulse
pulse_1
pump
purple
q
r
radio
rain
raise
range
reader
receiver
reception
record
recorder
recreation
rectifier
red
reel
refill
refrigeration
refrigeration_1
refrigerator
reject
relay
remember
reminder
remote
repeat
report
reset
resistance
response
rest
restore
restroom
reverse
rewind
rice
right
rings
riser
road
robot
roller
roof
room
rose
router
rumpus
run
s
safe
sales
satellite
saturday
sauna
save
saved
saved_messages
say_your_name
say_your_name_1
scene
scenes
schedule
school
screen
screw
seat
second
seconds
secretaries
security
security_off
select
semi
sensor
september
server
service
set
setback
setpoint
setting
settings
shaft
shed
shelter
ship
shock
shop
short
shower
shunt
shut
shutdown
shutter
side
signal
signin
sign_in
silence
siren
skylight
slave
sleep
sliding
slow
small
smartfit
smoke
sms
snow
socket
soft
solenoid
solenoid_1
solenoid_2
son
sort
sound
south
spa
spare
speak
speaker
speed
spill
sport
spotlight
spray
sprinkle
sprinkler
squash
stable
staff
staircase
stairs
stairway
stand
standby
standing
star
start
state
station
status
step
stop
storage
store
storey
stove
street
strike
strobe
studio
study
sump
sun
sunday
sunrise
sunset
supply
surge
swing
switch
system
t
table
talk
tamper
tank
tap
tape
tea
team
technology
telecom
telecom_1
telephone
telephone_1
temp
temperature
tennis
terrace
test
testing
text
thankyou
thank_you
thank_you_1
thank_you_2
thank_you_3
theatre
thermostat
third
this
this_message
thousand
thursday
tilt
time
time_1
time_program
to
toggle
toilet
tone
tool
tools
top
touch
touchscreen
tower
to_arm_security_system
to_change_date_and_time
to_end
tracking
train
transceiver
transfer
transformer
transistor
transmission
transmit
trap
trellis
trip
triple
trolley
trouble
tube
tuesday
turbine
tv
two_way
type
tyre
ulti
under
underfloor
underfloor_1
undergound
undergound_1
under_1
unit
unit_1
unlock
unset
up
uplight
upper
ups
upstairs
urine
user
users
user_1
utility
vacation
vacation_mode
vacuum
value
valve
variable
vault
vcd
vcr
vent
ventilator
ventilation
verandah
vesda
vest
vibration
video
villa
vision
vision_1
visitor
visitors
visitors_1
visitor_1
voice
voltage
volume
volume_2
w
wake
walk
walkway
walk_1
walk_in
wall
ward
wardrobe
warehouse
warm
warning
wash
washer
washing
washroom
waste
watch
water
way
weapons
wednesday
week
weight
welcome
west
wet
whine
white
wind
window
wine
wire
wireless
womens
wood
word
work
workshop
wrong
x10
xray
yard
year
yellow
yes
youhave
you_have
zero
zone
zoom
1
10
10th
11
12
13
14
15
15_1
16
16_1
17
18
19
20
2nd
30
3rd
4
40
4th
5
50
5th
6
60
6th
7
70
7th
8
80
8th
9
90
9th
a
abnormal
abort
abort_1
ac
accept
accept_1
access
access_1
accounts
acknowledge
acknowledged
action
action_1
action_2
activate
activation
active
actuator
add
address
add_1
aftertone
after_the_tone
air
aircon
airconditioner
aisle
alarm
alarm_1
alert
alert_1
all
am
amplifier
am_1
analog
and
annex
answering
answering_machine
antenna
apartment
appliance
appliances
april
april_1
aquarium
area
arm
armed
at
attic
august
auto
automatic
automatic_1
auxiliary
av
away
away_mode
away_mode_1
awning
b
baby
babys
back
backup
baggage
balcony
bar
barn
barrier
basement
basement_1
bath
bathroom
battery
beam
bedroom
begin
bell
belt
big
bin
birthday
black
blind
block
blower
blue
board
boil
boiler
boiling
bolt
booster
bottom
box
boys
break
breakdown
breaker
breakfast
breakglass
bright
brightness
building
burner
bus
butlers
button
bypass
c
cabin
cabinet
cable
cage
call
caller
call_1
camera
campus
car
card
care
carer
carpark
carporch
carriage
cartridge
case
casement
cat
cbus
cctv
cd
ceiling
cellar
centre
cer
chairman
chamber
chandelier
change
changing
channel
charger
check
children
chiller
chime
chimney
chute
cinema
circuit
class
clean
cleaner
cleaners
cleaning
clear
climate
cloakroom
clock
close
closet
co2
coat
code
codepad
codes
coffee
coil
cold
comfort
command
common
communication
compartment
compound
compressor
computer
condensation
condense
condenser
conference
confirm
confirmed
conservatory
console
contact
contactor
contactor_1
contactor_2
container
container_1
control
conveyor
conveyor_1
cooker
cooker_1
cooking
cooking_1
cool
coolant
cooler
cooling
copy
corridor
counter
court
crack
cubicle
cupboard
current
curtain
custom
cut
cytech
d
danger
dark
darkness
data
date
daughter
day
daylight
day_mode
db
db_1
dc
december
deck
degrees
dehumidifier
delay
delete
demand
department
description
desk
detected
detection
detector
dew
dial
digital
dim
dimmer
dimming
dining
din_rail
director
directors
disc
discharge
dishwash
dispensary
dispensing
disposal
distribution
dog
door
double
down
downlight
downstairs
drain
drainage
drapes
drawer
drawing
dress
dresser
dressing
drive
driveway
dry
dryer
drying
dsp
duress
dvd
dvr
e
earth
east
eib
eject
electric
electrical
electricity
electronic
elevator
elv
emergency
emission
empty
emsb
end
energy
engine
engineer
engineering
ensuite
enter
entertainment
enter_new_number
entrance
entry
environmental
equipment
erase
erased
erection
escalator
event
event_log
exhaust
exit
expansion
external
eye
f
factory
fail
failure
family
family_care
fan
fast
father
fault
faulty
fax
fcu
february
february_1
female
fence
fill
film
filter
finger
fire
fireman
fireplace
first
first_1
fitting
flag
flash
flat
float
flood
floodlight
floodlight_1
floodlight_2
floor
flow
fm200
fob
food
foot
footlight
for
force
forward
for_1
for_door_station
for_engineer_menu
for_home_control
for_messages
for_partitions
for_previous_menu
for_program_menu
for_security_menu
for_voice_station
fountain
foyer
foyer_1
freeze
freezer
friday
front
frost
fuel
full
function
furnace
g
gallery
games
gang
garage
garbage
garden
gas
gas_1
gate
general
generator
genset
girls
glass
goodbye
goodbye_1
green
greeting
greeting_message
grill
ground
group
gsm
guard
guest
gun
gym
h
half
hall
hallway
halon
hand
hangup
hang_up
hash
head
hear
heat
heater
heating
hello
help
hex
hifi
high
higher
high_temp
history
hold
holiday
home
hose
hot
hours
house
housecode
ht
hub
humidifier
humidity
hundred
hvac
hydraulic
hydraulic_1
i
ice
id
idle
immediate
in
incoming
indoor
infrared
inner
input
inside
installer
intake
intercom
interface
internal
internet
intruder
invalid
inverter
is
j
jacuzzi
january
january_1
july
june
k
karaoke
kennel
kettle
key
keyfob
keyless
keypad
keys
kitchen
l
lab
laboratory
lamp
land
landing
landscape
laser
last
latch
latched
laundry
lavatory
lawn
leak
leakage
learn
leave
leave_your_message
left
level
library
lift
light
lights
line
link
listen
living
load
lobby
local
location
lock
loft
log
loop
loud
lounge
louvre
low
lower
lo_temp
lt
luggage
lumber
lutron
m
machine
macro
mahjong
maid
maids
mailbox
mailboxes
main
mains
maintenance
male
manager
managers
march
march_1
marketing
master
maximum
may
may_1
meals
medical
medicine
medicine_1
medium
meeting
meeting_1
melt
melt_1
mens
mens_1
menu
message
messages
meter
meter_1
mezzanine
mezzanine_1
mezzanine_2
mezzanine_3
microphone
middle
minimum
minutes
mobile
mode
modem
module
moisture
monday
monetary
monitoring
month
moon
mother
motion
motor
move
movement
movie
mp3
msb
music
n
name
network
new
new_message
new_messages
next
night
night_mode
no
noise
normal
north
not
november
NUL0.WAV
null
number
numbers
nursery
o
observatory
october
of
off
office
oh
oil
ok
on
open
operate
options
or
out
outdoor
outer
outgoing
output
outside
oven
over
overflow
overheating
overload
override
oxygen
p
pabx
pabx_2
pad
pager
pan
panel
panic
pantry
park
parking
partition
party
pass
passageway
passive
path
patio
pause
pause_1
pcu
pdu
pelmet
pendent
penthouse
perimeter
personnel
pet
phone
pill
pin
pipe
pir
pit
place
plant
play
please
plug
pm
pm_1
point
points
pool
porch
pot
pound
pounds
powder
power
pre
preaction
preactivation
precision
press
pressure
previous
printer
private
program
programming
projector
protect
protected
protection
public
pulse
pulse_1
pump
purple
q
r
radio
rain
raise
range
reader
receiver
reception
record
recorder
recreation
rectifier
red
reel
refill
refrigeration
refrigeration_1
refrigerator
reject
relay
remember
reminder
remote
repeat
report
reset
resistance
response
rest
restore
restroom
reverse
rewind
rice
right
rings
riser
road
robot
roller
roof
room
rose
router
rumpus
run
s
safe
sales
satellite
saturday
sauna
save
saved
saved_messages
say_your_name
say_your_name_1
scene
scenes
schedule
school
screen
screw
seat
second
seconds
secretaries
security
security_off
select
semi
sensor
september
server
service
set
setback
setpoint
setting
settings
shaft
shed
shelter
ship
shock
shop
short
shower
shunt
shut
shutdown
shutter
side
signal
signin
sign_in
silence
siren
skylight
slave
sleep
sliding
slow
small
smartfit
smoke
sms
snow
socket
soft
solenoid
solenoid_1
solenoid_2
son
sort
sound
south
spa
spare
speak
speaker
speed
spill
sport
spotlight
spray
sprinkle
sprinkler
squash
stable
staff
staircase
stairs
stairway
stand
standby
standing
star
start
state
station
status
step
stop
storage
store
storey
stove
street
strike
strobe
studio
study
sump
sun
sunday
sunrise
sunset
supply
surge
swing
switch
system
t
table
talk
tamper
tank
tap
tape
tea
team
technology
telecom
telecom_1
telephone
telephone_1
temp
temperature
tennis
terrace
test
testing
text
thankyou
thank_you
thank_you_1
thank_you_2
thank_you_3
theatre
thermostat
third
this
this_message
thousand
thursday
tilt
time
time_1
time_program
to
toggle
toilet
tone
tool
tools
top
touch
touchscreen
tower
to_end
tracking
train
transceiver
transfer
transformer
transistor
transmission
transmit
trap
trellis
trip
triple
trolley
trouble
tube
tuesday
turbine
tv
two_way
type
tyre
ulti
under
underfloor
underfloor_1
undergound
undergound_1
under_1
unit
unit_1
unlock
unset
up
uplight
upper
ups
upstairs
urine
user
users
user_1
utility
vacation
vacation_mode
vacuum
value
valve
variable
vault
vcd
vcr
vent
ventilator
ventilation
verandah
vesda
vest
vibration
video
villa
vision
vision_1
visitor
visitors
visitors_1
visitor_1
voice
voltage
volume
volume_2
w
wake
walk
walkway
walk_1
walk_in
wall
ward
wardrobe
warehouse
warm
warning
wash
washer
washing
washroom
waste
watch
water
way
weapons
wednesday
week
weight
welcome
west
wet
whine
white
wind
window
wine
wire
wireless
womens
wood
word
work
workshop
wrong
x10
xray
yard
year
yellow
yes
youhave
you_have
zero
zone
zoom
