Threads: 5
When i come back to home i disarm the Comfort. There is a response associated to \"disarm\" event, turning on a light.
Often, instead of turning on only this light, Comfort turns on another light on the same house code, or all lights in the house code A or all lights in the Housecode B I\'ve Comfort Ultra Gen 2 5.164
Is it a Comfort issue, or maybe X10 transceiver issue?
Thanks.
Threads: 11
Unlikely to be a comort problem as such, first check you have no unwanted X10 commands in any other responses, if I remember there are some in the basic CCF file.
If it is not that, then bear in mind X10 can be pretty unreliable if your mains has noise on it and you can get signal attenuation over long distances. You usually find it is one or two appliances that cause the main noise on the ring main. I have a coffee maker that totaly blocks all X10 in certain parts of the house. It is a case of elminating things one by one.
Best of luck
Threads: 55
This seems like a copy/paste of my post about same problem.
I still have those kind of issues and i\'m replacing all X10 with EIB devices.
Threads: 5
Hello :
The problems appears after replace confort I for comfort II.
I had Confort I more o lesse 6 years and no problems of this type.
BR.
José Gonçalves
