Threads: 62
Is there a way to stop the Date/Time announcement from Comfort to CBus? I had the strange case where lightning \'upset\' my system again. After I got home and reset the system it then proceeded to think it was still 5/3/2010 instead of 7/3/2010. This then changed my PAC time and date and all my nightly programs on CBus started to execute in the middle of the day.
Thanks,
Ingo
Threads: 887
You cannot stop the date and time sync betwen Comfort and Cbus
Make sure you have a TPB or APB surge arrestor oin the telephone line as that is the most susceptible to lightining surges
Threads: 62
I have no telephone connection on my system, I suspect the long cable runs to all my 64 zones to be the \'pickup\' for the EM interference. The rest of the system is well protected as per our previous discussion on lightning.
Threads: 887
Correct, the cable runs may cause high voltage to be picked up, especially from magnetic contact or sensors on the windows
Comfort is well protected so that it should not be damaged unless there is a direct lightning strike on the sensors
One of the features to be implemented in a new generation UCM/CBus will be an option to send Comfort Time to Cbus just like the UCM/KNX
Threads: 62
Thanks Chiu,
I saw the KNX feature and that is why I asked about the CBus side.
Ingo.
Threads: 887
No it is not imminent, stil in the planning stages.
The main difference in the hardware will be the addition of an EEPROM IC. Current UCM/Cbus has an empty socket for the EEPROM so it can be upgraded easily by adding the IC and upgrading firmware.
You say you have a time synchronisation problem due to DST
Why is this a problem. Comfort\'s time should be correct as it automatically adjusts for DST, and it should update Cbus time so the times should be synchoriised. Why is your time not synchronised
