\"ARM FAILURE\" occurs when trying to arm to AWAY mode, but the user did not leave the house and close the Entry Door. Arm to Away Mode when everyone is leaving the house. If someone will be in the house, arm to Nighjtor Day mode instead.
Arm Failure also occurs if the door is closed but one of the sensors is activated.
The zone causing an Arm Failure is recorded in the Event Log, immediaitely before the Arm Failure Event
For example, for arming to Away Mode
05/09 05:26 Sign in - User #, 1
05/09 05:26 Mode Change #Security Off
05/28 08:30 Zone Activation # FrontDoor (1)
05/09 08:30 Alarm Type #ARMFAILURE (4)
05/09 08:30 Sign in - User #, 1
05/09 08:30 Alarm Type #ALARMERASED (20)
The event (shown in bold) showing Front door is open at the time of Arm Fail means that the Front Door was not closed, hence causing Arm Failure.
Note that a noot uncommon problem for magnetic contacts for doors and windows is the deterioration of magnetic force over time, or the misalignemnt between magnets, or the increases in resistance of wire resistance over time leading to incorrect detection of opening and closing
If another zone is recorded instead of the Entry door, it means that after the Entry door was opened and closed, that zone was detected open in the 6 seconds prior to final arming
If No Zone is recorded, it means that NO zone was found open at arm failure, ie the Exit Time timed out. The only reason for this would be that the Entry door was not even opened, hence the exit time timed out.
eg
05/13 14:23 Alarm Type # ArmFail (4)
For arming to Night and Day Modes, a zone is always recorded for arm failure, as the system waits for all zones to be closed in order to arm, and does not wait for the Entry door to open as in Away Arming
This is a great help to identify the cause of an Arm Failure
eg
