Threads: 62
Chiu,
I have a 1223/5 as well so I assume that will also not be compatible.
I do have one of those new SIM\'s as shown in the picture but how can I see that it\'s the ST7 version? There are no markings on the board itself.
Ingo
Threads: 872
The new SIMs are all of the ST7 version. There may be no version marking
At the moment the main advantage of the new firmware is the text label command
It may be possible to get an upgrade at a nominal cost for thise =who have the old version
Threads: 872
If your UCM/Cbus looks like the one in the first post, thenit is a second generation one whose firmware can be upgraded
If yours has a big square IC in a socket, marked CBUS 5.99 or below then it is the first generation type whose firmware cannot be upgraded by using a UCM and Comfigurator
