Comfigurator - migrating from V223 to V328
I am migrating from V223 to V328.
How can I successfully import my old .ccl into the new version.
Tried the import option and it dropped off all my responses and settings. The only section that seems to have imported correctly is the Gereral Tab.
Is there a conversion process or a utility to convert ?
You can read ccl files created by Comfigurator 2 using Comfigurator 3. In Comfigurator 3, do File Open > select Files of type .ccl
This reads the ccl file. save them as .cclx file type
Ok, I used up all my dumb questions for todayBig Grin
I upgraded my firmware on Comfort to 5.218 and my *serial ucm to 6.007
When I try to connect to Comfort i get \'Failed to write to Ucm\' using Comfigurator 3.28
If I use the the newer UCM with the serial sister board with ver 6.007 I get connectivity.
What\'s the buzz ?
PS *the serial ucm works with Comfigurator 2.28
Hi I\'m using one of the older UCM/Serial boards (serial connector and jumper onboard) with 6.007 without any problems.  I\'m using the latest Comfigurator 3.3.1 though.
I guess you\'ve seen that issue that Ingo found in Comfigurator and serial connections if the \"via KT03\" box is ticked.
Please send me the url with reference to KT03
Loaded Comfig 331
Error \' No response from UCM\' using older UCM with ver 6.007
Help I need somebody
See this thread at the bottom:
http://www.comfortforums.com/forum20/2382.html
Changed to USB and KT03 was unckecked.
Changed back to Serial (no Rs232)
Tried connecting again, same problem \'No response from Ucm\'
When back to newer UCM with sister board ver 6 and I get the came error \'No response from Ucm\'. Going in circles
Check shunt SW8-H should be off (Hardware handshake)
SW8- F and G should also be off
If that still happens uninstall and reinstall Comfigurator
There may be some settings left over from the older Comfigurator
