C-Bus UCM
Hi THere , Can Anybody help Me. i Accidentaly Pulled My C Bus Cable out Of the Ucm Cbus /ucm On the Comfort Board Witht The C Bus Chip 5.154 On the Board is A Black 10 Pin Socket Where The C Bus Clipsal Module Plugs Into.
The C Bus Sim Has Unplugged From the Comfort Board And Now I Canot Send Cbus to Comfort Commands, However Comfort To C Bus Works ??? Maybe i Plugged the c Bus SIM into the Wrong 5 Sockets on the Board.
On the Clipsal Board Marked 1223/7 there Are 4 Pins That Go into The Socket With 10 Pins in. Do they Fo into the Left 5 Or Rear 5 or Front ?? Please Help
Thaks, Clinton
Clinton,
Have a look at the picture below, I drew a quick box around the connector, the first pin should go into the bottom right corner - see the little red dots I put on there.
Also check with CBus Toolkit that the CBus side didn\'t lose it\'s config or addressing.
Ingo
Thanks Ingo. i Have Lost The unit in Toolkit. it Came up Last Time As network Bridge..!!! Go Figure. it Took Me A Whole Day to identify The Problem.. now to Fix it As They Want 2 K For A new one !!. Will Try it Just now, Its A Bit Late now And Dont want Sirens Going off And upsetting the neighbours Again.. Thanks Will keep You Posted. Thanks for the image.. i THINK I Got the Connector Wrong Yesterday But i Hope its okay Still...
Hi Ingo
Thanks For Your help.. IT WORKS And I Now Have It Back in Toolkit.. I Feel Like Such A Twat...If Ever You in Knysna Give Me A Call And We Go For Coffee Or So
Thanks, Clinton
Sure, no problem. I might just be there one day for a Mountain Bike race...
Mountain Bike Race, Cool
Its In Toolkit Again But C Bus Cant Send Commands
I Get A    Communications Failure 18             ???
Will Do reset In Morning..
Thanks So Far
Any Idea What is   Communications Failure 18
Communications Failure 18 means the UCM #2 (presumably the UCM/Cbus) is not communicating
Check the UCM ID shunt is set to 2, ie SW7 A removed and do a reset of the UCM/Cbus
Its In Tool Kit But not receiving C Bus Commands... Looks Like i Might Have To Get A new One After all...............
Did you check the UCm ID ?
Are you still getting Communications Failure 18?
Thanks For the Advice i Will Try Tonight To Check id
Still Getting Communications Error 18
Yet When The C Bus sim Was Pluged in Wrong the PIRs in The House Would Still Communicate And SEND Instructions TO c Bus
Once i Plugged it in Corectly.....There is
No Communication From or To C Bus......
