Comms Issues
Hi All,
I have been trough a bit of pain with updating the config to the system. Chiu has been brilliant in supporting me to a point where I got the latest system firmware installed.
Configurator 3.3.3
Frimware 6.005
UCM 10 6.002.
Basically the upgrading of a config change works ok sometimes and not other. I have disabled timeout on the DS manager which helped get the system firmware on. For the rest of the time what I have been doing when uploading stops is pressing the reset button on the ETH UCM. However, I have now put the case on and its a pain to do this as I end up triggering the tamper alarm every time I have to hit the reset, check out my other posts for help with tamper alarm :-)
I get no interruption when doing a ping - t of the system so it\'s on the network.
Now I have been away for around 3 weeks and the iPhone app has connected seemlessly for all this time. However a couple of days ago the app said it was connected, but when I entered my code it did not change to the keypad screen as normal. Also I logged on to the configurator and it would not talk to the system.
I pressed the reset on the ETH UCM without making any changes to comfigurator, iPhone or the network and everything came to life again.
I realise I need to upgrade the ETH UCM to 6008 and intend doing that when I get a chance over the next week.
But has anyone got any ideas on what I can to in order to keep the connection alive without having to keep pressing the reset button. This is just bad as I have triggered the tamper alarm a couple of times late a night, see my other post asking for help on removing the case without triggering the alarm :-)
Cheers
Lee
PS Sorry If I have posted this in 2 different places please remove duplicate if I have.
Cheers
Lee
Are you connected to the UCM/Ethernet on the Local LAN or remotely by Internet when you do a write to Comfort? When does the transfer stop? Can you send the Monitor I/O trace when this happens.
Are you sure you need to press the Reset button on the UCM when this happens?
Did you just try to Login again by Comfigurator?
Can you see the UCM using the DS Manager when it happens?
Hi Ident,
iPhone connects via Internet.
Say\'s connected but when I enter my 4 digiet code it does not change screens
Comfigurator connects via local LAN
Just get \"can\'t connect to UCM\".
When I press the reset on the ETH UCM it all starts to works fine again with no additional actions needed.
It has taken 3 weeks for comms to fail when I am just using the iPhone, however when connecting via Comfigurator it seems to crash during my time uploading / making changes within 1 - 4 hours max
if it works it goes through great, if it failes then the UCM monitor says LI*** and when I get the error message \"can\'t connect to UCM\" UCM monitor repeats the LI*** message.
I have looked all over the forums and I really don\'t understand how I can update the ETH UCM. System 6005, ETH 6002. Can you point me to a post that says how its done?
Just wondering if the update might help my connection.
Chiu has connected to my system by teamviewer a while ago when I was trying to get the system firmware updated and could see the error message at the same time DS manager could see the system.
Ping test show system is available when it stops working.
Hope this all make sense if not please tell me what you need as I really want to get to a stable comms so that I don\'t have to keep opening the system up to press the reset button.
All the best
Lee
iPhone login problem when it does not turn green. Is that a common occurence? Ocasionally overf the internet some characters are lost and even though you entered the correct code the iPhone dooes not get the log in reply. I get the same problemn and there may not be much that can be done about it except to try again
Upgrading the UCM/Ethernet firmware is by Direct connection to PC method, see http://www.comfortforums.com/forum4/2283.html
I dont remember if you had a lot of problem with this before due to the disconnection problem. If so I would not advise attempting it yet until the disconection problem has been solved
I recall that we we saying the problem may be in the network, that it causes disconnection for some reason
Have you tried connecting to the UCM/Ethernet direct to the computer using a cross cable? This wiill eliminate the network and we can see if the communications is good
Hi Ident.
Sorry been away for a while so forgot about the xover cable idear. I will pick one up from work tomorrow and give it ago.
Cheers
Lee
Hi Ident
I have tried using an xover cable since last night, unfortunately it failed this morning with the same “no response from UCM” message. Same process seemed to work and pressing the reset on the ETH UCM seemed to clear to problem. This has only happened once so will keep trying to see if it was a one off though.
I will add that a couple of days ago when I was using comfigurater and it stopped working that the iPhone app continued to give feedback on the zone states and I could turn lights on and off. This only happened for a few minutes but in my mind proves comms where still alive.
I took a copy of the log file at the point of failure which you can see below.
Cheers
Lee
[size=\"3\"][font=\"Calibri\"]> LI****[/font][/size]
[size=\"3\"][font=\"Calibri\"]> UL000003[/font][/size]
[size=\"3\"][font=\"Calibri\"]> V?[/font][/size]
[size=\"3\"][font=\"Calibri\"]> v?[/font][/size]
[size=\"3\"][font=\"Calibri\"]> U?[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?11[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?12[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?13[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?14[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?15[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?16[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?17[/font][/size]
[size=\"3\"][font=\"Calibri\"]> u?18[/font][/size]
[size=\"3\"][font=\"Calibri\"]< LU02[/font][/size]
[size=\"3\"][font=\"Calibri\"]< DL00000305FF22D7[/font][/size]
[size=\"3\"][font=\"Calibri\"]< V?FE060522200100[/font][/size]
[size=\"3\"][font=\"Calibri\"]< v?05FF23010203FFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< U?0A060211[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?110A0602[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?120E05DA[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?13FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?14FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?15FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?16FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?17FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< u?18FFFFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> SR01[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DT20111118221029[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL00000205FFFA[/font][/size]
[size=\"3\"][font=\"Calibri\"]< OK[/font][/size]
[size=\"3\"][font=\"Calibri\"]< DT2011111822102900[/font][/size]
[size=\"3\"][font=\"Calibri\"]> L00031C010507080302040E11130B17151416101C1B120A0C09001D19181F1C2F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL002709BC700001FF5AFFFF2D1F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0032020A01C1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL003502055074[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL003820101E05070002000308C00123050708FFFFFFFFFFFF14110607000200031CC00656[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL005820071CFFFFFFFFFF04000403010012FF05021002100901FFFFFFFFFFFFFF00FFFF23[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL007819FFFFFFFFFFFFFFFFFF00FFFF02020408030301040407020D0441[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL010820051E3412FF000D3412FF000D0F51122F51120F510D0D51120A221204220D042298[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL01281C1224221224220D40621160621140591160593240552D40552D40552D9D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0180204C001300404C141314A34C010014804C040004804C02000880260A000A80260A21[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL01A020300A80261413288026010004803F1430148036080004A23614001480003C701749[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL01C02001BCE02E027070170370E02E047C1400053860090330C800073C7017003C280077[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL01E020067014000330E47F0A30EC130B307017083CB00406302800043014000B303C00CF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0200140230701703307097FF1000800000940100000000D3[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL021820214202FFFF2E012F01213102FFFF2C012D01225201FFFF32013301235701FFFF04[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL02382030013101004300FFFF00000000004800FFFF00000000005600FFFF000000000068[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0258204000FFFF0000000001010101010101010101010101010101010101010101010130[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL027820010101010101010101010101010101010101010101010101200900000000000025[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL029820000000000000000000000000000000000000000000000000000000000000000046[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL02B80800000000000000003E[/font][/size]
  [size=\"3\"][font=\"Calibri\"]OK[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL02D0201805000000000000000000000000000000000000000000000000000000000000F1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL02F0200000000000000000000000000000000000000000000000000000340100000000B9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL068805020001010069[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0694013C29[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL069701B4AE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL069902D30389[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL069C0200FF5D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL069F01FF5B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL06A20D03030000000A010350000000FCEB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0709206E00650066006700680069006A006B0079007300FF006D006F00480049004700EB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL072902C21EEE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07360100C2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07390106B9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL073B2041510000000000000000000000000000000000000000000000000000000000000C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL075B2000000000000000000000000000000000000000000000000000000000000000007E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL077B01007D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07800801020000000000006E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07A0100000000000000000000000000000000049[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07D0201203FF2626FFFFFFFFFFFFFF0104181407FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL07F016FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71060887[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL083612FFFF4343437FFF7F7F7F7F7F7F7F7F7FFF7F76[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL085605060308083C48[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0862050A1E051E0541[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0869200107779530966FFFFFFFFF0107595284858FFFFFFFFF0101623855684FFFFFFF3E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL088920FF0101623857942FFFFFFFFF0101158405810FFFFFFFFF00FFFFFFFFFFFFFFFF7A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL08A920FFFF00FFFFFFFFFFFFFFFFFFFF0001623842351FFFFFFFFF00000000000000000E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL08C92000000000000000000000000000000000000000000000000000000000000300000C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL08E9200000000000000000000000000000000000000000000000000000000000000000EF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0909200000000000000000000000000000000000000000000000000000000000000000CE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL09292000000000000000000000000000000000000000000000005400008A23385B01B069[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL09491823535B01FF05003F00FF00454500C523205B01FF2300180159[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0A0820FC860101FCC6010114860601048606013C86010154820601FC82010100A300058B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0A2820FFA60E05FFA60C05FF860D05FF86090BFC860B0B28860F01FF860101A8820F01F9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0A48207C8619050C860101FF820101FF860B0B0CA419053C860E05FF860C0500830005FB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0A6820FC830101FF860101FFA601013C8201010C810101008B000000AB0000FFFFFFFF3E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0B0020420000000000011601000080010000000080010000000080050000000080010073[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0B202000000080050000000000122501000000121C010000805200000000801221010043[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0B402000001200000000000C000000000012000000000012000000008012000000008041[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0B6020000000000000000000000000000000000000000000000000000000000000004A2B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0B802001000000174A01000000174A01000000004A010000000000000000000000000045[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0BA020000000000000000000000000000000000000000000000000000000000000000035[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0BC020000000000000000000000000000000000000000000000000000000000000000015[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0BE0200000000000000000000000000000000000000000000000000000000000000000F5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0C00200000000000000000000000000000000000000000000000000000000000000000D4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0C20200000000000000000000000000000000000000000000000000000000000000000B4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0C4020000000000000000000000000000000000000000000000000000000000000000094[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0C6020000000000000000000000000000000000000000000000000000000000000000074[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0D802016BAFFFF02BAFFFF0217BAFF17BAFFFF1719FFFF3DBAFFFF3D19FFFF4519FFFF57[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0DA0202019FFFF101B19FF391B19FF250619FF2506D7FF5D0619FF160619FF0206FFFF54[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0DC020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12C7FFFFC310FFFFC339FFFF17C3FFFFA9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0DE020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0E0020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0E2020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0E4020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0E6020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0F8020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0FA020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0FC020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL0FE020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL100020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL102020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL104020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL106020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL108020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL10A020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL10C020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL10E020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL110020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL112020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL114020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL116020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL11802000000000000000000000000000000000000000000000000000000000000000004F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL11A02000000000000000000000000000000000000000000000000000000000000000002F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL11C02000000000000000000000000000000000000000000000000000000000000000000F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL11E0200000000000000000000000000000000000000000000000000000000000000000EF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1200200000000000000000000000000000000000000000000000000000000000000000CE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1220200000000000000000000000000000000000000000000000000000000000000000AE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12402000000000000000000000000000000000000000000000000000000000000000008E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12602000000000000000000000000000000000000000000000000000000000000000006E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12802000000000000000000000000000000000000000000000000000000000000000004E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12A02000000000000000000000000000000000000000000000000000000000000000002E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12C02000000000000000000000000000000000000000000000000000000000000000000E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL12E0200000000000000000000000000000000000000000000000000000000000000000EE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1300200000000000000000000000000000000000000000000000000000000000000000CD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1320200000000000000000000000000000000000000000000000000000000000000000AD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13402000000000000000000000000000000000000000000000000000000000000000008D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13602000000000000000000000000000000000000000000000000000000000000000006D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13802000000000000000000000000000000000000000000000000000000000000000004D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13A02000000000000000000000000000000000000000000000000000000000000000002D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13C0200000000018011801000000000000000000000000000000000000000000000000DB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL13E0200000000000000000000000000000000000000000000000000000000000000000ED[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1400200000000000000000000000000000000000000000000000000000000000000000CC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1420200000000000000000000000000000000000000000000000000000000000000000AC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14402000000000000000000000000000000000000000000000000000000000000000008C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14602000000000000000000000000000000000000000000000000000000000000000006C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14802000000000000000000000000000000000000000000000000000000000000000004C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14A02000000000000000000000000000000000000000000000000000000000000000002C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14C02000000000000000000000000000000000000000000000000000000000000000000C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL14E0200000000000000000000000000000000000000000000000000000000000000000EC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1500200000000000000000000000000000000000000000000000000000000000000000CB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1520200000000000000000000000000000000000000000000000000000000000000000AB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL15401E0000000000000000000000000000000000000000000000000000000000008D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL15602000000000000000000000000000000000000000000000000000000000000000006B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL15802000000000000000000000000000000000000000000000000000000000000000004B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL15A02000000000000000000000000000000000000000000000000000000000000000002B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1620200000000000000000000000000000000000000000000000000000000000000000AA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16402000000000000000000000000000000000000000000000000000000000000000008A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16602000000000000000000000000000000000000000000000000000000000000000006A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16802000000000000000000000000000000000000000000000000000000000000000004A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16A02000000000000000000000000000000000000000000000000000000000000000002A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16C02000000000000000000000000000000000000000000000000000000000000000000A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL16E0200000000000000000000000000000000000000000000000000000000000000000EA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1700200000000000000000000000000000000000000000000000000000000000000000C9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1720200000000000000000000000000000000000000000000000000000000000000000A9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL174020000000000000000000000000000000000000000000000000000000000000000089[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL176020000000000000000000000000000000000000000000000000000000000000000069[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL178020000000000000000000000000000000000000000000000000000000000000000049[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL17A020000000000000000000000000000000000000000000000000000000000000000029[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL17C020000000000000000000000000000000000000000000000000000000000000000009[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL17E0200000000000000000000000000000000000000000000000000000000000000000E9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1800200000000000000000000000000000000000000000000000000000000000000000C8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1820200000000000000000000000000000000000000000000000000000000000000000A8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL184020000000000000000000000000000000000000000000000000000000000000000088[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL186020000000000000000000000000000000000000000000000000000000000000000068[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL188020000000000000000000000000000000000000000000000000000000000000000048[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL18A020000000000000000000000000000000000000000000000000000000000000000028[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL18C020000000000000000000000000000000000000000000000000000000000000000008[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL18E0200000000000000000000000000000000000000000000000000000000000000000E8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1900200000000000000000000000000000000000000000000000000000000000000000C7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1920200000000000000000000000000000000000000000000000000000000000000000A7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL194020000000000000000000000000000000000000000000000000000000000000000087[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL196020000000000000000000000000000000000000000000000000000000000000000067[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL198020000000000000000000000000000000000000000000000000000000000000000047[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL19A020000000000000000000000000000000000000000000000000000000000000000027[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL19C020000000000000000000000000000000000000000000000000000000000000000007[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL19E0200000000000000000000000000000000000000000000000000000000000000000E7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1A00200000000000000000000000000000000000000000000000000000000000000000C6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1A20200000000000000000000000000000000000000000000000000000000000000000A6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1A4020000000000000000000000000000000000000000000000000000000000000000086[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1A602000000102030400000000000000000000000000000000000000000000000000005C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1A801C000000000000000000000000000000000000000000000000000000004A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1AC4200004040404020000000007000000000000000000000000000000000000000000E9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1AE41C00000000000000000000000000000000000000000000000000000000E6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1B2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1B4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1B6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1B8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1BA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1BC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1BE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1C0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1C2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1C4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1C6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1C8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1CA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1CC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1CE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1D0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1D2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1D4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1D6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1D8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1DA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1DC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1DE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1E0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1E2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1E4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1E6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1E8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1EA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1EC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1EE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1F0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1F2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1F4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1F6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1F8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1FA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1FC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL1FE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL200820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL202820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL204820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL206820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL208820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL20A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL20C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL20E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL210820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL212820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL214820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL216820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL218820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL21A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL21C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL21E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL220820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL222820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL224820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL226820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL228820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL22A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL22C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL22E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL230820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL232820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL234820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL236820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL238820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL23A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL23C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL23E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL240820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL242820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL244820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL246820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL248820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL24A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL24C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL24E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL250820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL252820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL254820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL256820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL258820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL25A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL25C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL25E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL260820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL262820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL264820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL266820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL268820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL26A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL26C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL26E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL270820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL272820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL274820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL276820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL278820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL27A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL27C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL27E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL280820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL282820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL284820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL286820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL288820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL28A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL28C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL28E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL290820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL292820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL294820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL296820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL298820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL29A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL29C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL29E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2A0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2A2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2A4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2A6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2A8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2AA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2AC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2AE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2B0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2B2820C16500000330306B0180670000FF21FF4B010768000000515149034E0800000093[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2B482006FF4B0487690000FF70704903806A0000FF32FF4A01876C0000FF0202490387D0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2B68206D0000FF01014903C16B0000FF20FF4B010379000000FFFF4A01C1660000FF37DB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2B8820374B01C2644A010310FF4B01CD710000FF51FF4B01C06E0000FC02FF4801C06F5F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2BA82000000331FF4A0100C50000007070480500867A000001FF480480EE00000301FFE0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2BC820480600BF00000001FF4804008300000006FF480406C6000000FFFF4A010BE500BB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2BE82000007373490380F20000FF50FF480407F8000000505049030AD5000000FFFF487F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2C0820060077000000FFFF480480EE0000FF01FF4806074700000352524903804A00001F[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2C2820FFFFFF4806000900000000004806807F00000313FF4904FFFFFFFFFFFFFFFFFF92[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2D5620800101FFFFFFFFFF800100FFFFFFFFFF800201FFFFFFFFFF800200FFFFFFFFFF69[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2D7620800301FFFFFFFFFF800300FFFFFFFFFF800401FFFFFFFFFF800400FFFFFFFFFF41[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2D9620800501FFFFFFFFFF800500FFFFFFFFFF800601FFFFFFFFFF800600FFFFFFFFFF19[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2DB620800701FFFFFFFFFF800700FFFFFFFFFF800801FFFFFFFFFF800800FFFFFFFFFFF1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2DD620810101FFFFFFFFFF810201FFFFFFFFFF810302FFFFFFFFFF810402FFFFFFFFFFDD[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2DF620810503FFFFFFFFFF810603FFFFFFFFFF810704FFFFFFFFFF810804FFFFFFFFFFA5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2E16208C2030C341010FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2E3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49009202026400FFFFFFFFFFFFFFFFFF52[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2E5620C3410105FFFFFFFFC3410107FFFFFFFFC3410205FFFFFFFFC3410207FFFFFFFF3E[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2E7620C3410305FFFFFFFFC3410307FFFFFFFFC3410405FFFFFFFFC3410407FFFFFFFF16[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2E9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2EB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC34C0105FFFFFFFFC34C0107FFFFFFFFE8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2ED620C20700053300FFFFFFFFFFFFFFFFFFFF4A42C20700053100FFFFFFFFFFFFFFFF62[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2EF620490092010304FFFF490092010204FFFF0AFFFFFFFFFFFFFF4900730949098E0251[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2F162002480271024800FFFFFFFFFFFFFFFFFF841002730101FFFF4900730949098E02ED[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2F36200248014800FFFFFFFFFFFFFFFFFFFFFF490092070249098E02034700FFFFFFFFE7[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2F5620C3410001FFFFFFFFC341000DFFFFFFFF090601400AFFFFFF4701FFFFFFFFFFFFB4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2F7620490073024702FFFF490073024704FFFF490073024803FFFF490073024801FFFF23[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2F962049009102014802FFFFFFFFFFFFFFFFFF8410027302400FFFFFFFFFFFFFFFFFFFAC[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2FB620FFFFFFFFFFFFFFFF08C3410001FFFFFFFFFFFFFFFFFFFFFFC512000100FFFFFF2C[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2FD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF821405FFFFFFFFFF821406FFFFFFFFFFBE[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL2FF620490092010205FFFF56087309C208001E000083070053078F04035508710115FFBB[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL301620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL303620490A720448004802FFFFFFFFFFFFFFFF87011EFFFFFFFFFFC3410003FFFFFFFF83[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL305620841001FFFFFFFFFF841000FFFFFFFFFF08FFFFFFFFFFFFFF5B01FFFFFFFFFFFFE4[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL30762063205B08FFFFFFFF63405B04FFFFFFFF63205B07FFFFFFFF5B1BFFFFFFFFFFFF09[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL3096206320860600FFFFFF63805B0BFFFFFFFF5B18FFFFFFFFFFFF63805B0AFFFFFFFF18[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL30B62063805B09FFFFFFFF5C01581EFFFFFFFF63805B24FFFFFFFF5E01FFFFFFFFFFFF31[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL30D6205E02FFFFFFFFFFFF5B1CFFFFFFFFFFFF63805B11FFFFFFFF850801FFFFFFFFFF3B[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL30F6204200FFFFFFFFFFFF4201C20800037500FFFFFFFFFFFFFFFF5D025B19FFFFFFFF32[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL31162016FFFFFFFFFFFFFF5A00C20800147C00FFFFFFFFFFFFFFFF5A01FFFFFFFFFFFF89[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL3136205812FFFFFFFFFFFF4F0E72084A2FC201012C3000FFFFFFFFFFFFFFFFFFFFFFFFB1[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL315620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL317620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL319620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL31B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL31D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL31F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL321620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL323620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL325620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL327620FFFFFFFFFFFFFFFFC3420405FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46[/font][/size]
< OK
> DL33F620FFFFFFFFFFFFFFFFC3480105FFFFFFFFC3480107FFFFFFFFFFFFFFFFFFFFFFFFAB
< OK
> DL3416204F0973024E01FFFF4F0972024E01FFFF4F0A73024E02FFFF4F0A72024E02FFFF2C
< OK
> DL3436204F0B73024E03FFFF4F0B72024E03FFFF4F0C7300FFFFFFFF4F0C7200FFFFFFFFA8
< OK
> DL345620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76
< OK
> DL3476204909730107FFFFFFFFFFFFFFFFFFFFFF49038E06138E03078D2E01FFFFFFFFFF32
< OK
> DL349620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49009102044AD6FF49098F0102C1490039
< OK
> DL34B620920A024003C207001EE50071024A49FF8D2E014908910302923604C20300B42C30
< OK
> DL34D62001C204012C3001C20A021C3101C20646503201C2071B4E3301C20300F02D01C2F9
< OK
> DL34F62004003C3001C20500C82F01C20A01723101910301925B03C20302712C01C2040164
< OK
> DL351620633001C20A02EE3101C20442683001C20600B03201C20A01773101C2060E102942
< OK
> DL35362001C20A0FA03001C20601183301C203015E2D01C20A00CC3101C205012C2F01492A
< OK
> DL35562004923A05C20303842C01C204012C30017102715EC20A02B43101C2060E103201D4
< OK
> DL357620C2044C2C3001C20601043301C20300962D01C20500502F01C20A00643101490842
< OK
> DL3596209221068D2C01C2060E103201C2071C202901C20340742D01C20600C83301C20429
< OK
> DL35B62000AF3101922B078D2C01C2060E1032017102711EC2071C202901C203300C330117
< OK
> DL35D620C20300B42D01C205012C2F01C20A00FA3101FFFFFFFFFFFF4F047203821401C7F2
< OK
> DL35F620FFFFFFFFFFFFFFFF4F027205C702BAD5FFFFFFFFFFFFFFFF491772024F047210FC
< OK
> DL361620C717BAD517BAD5820401C2400E101801FFFFFFFFFFFFFFFF49038E1B088D6B01D3
< OK
> DL363620C20200B42D014917720E560B720A4B02C20C070800004C02FFFFFFFFFFFFFFFFA1
< OK
> DL36562049038E13088D6A01C20100B42F0149177206C20B02580000FFFFFFFFFFFFFFFFC9
< OK
> DL36762049038E09088D2901C20200B4330149177208560B72044B074B06FFFFFFFFFFFF98
< OK
> DL369620C51200021EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC51200030FFDFFFF4C
< OK
> DL36B620C512000300FFFFFFC51200050FFDFFFFC512000500FFFFFFC51200070FFDFFFF76
< OK
> DL36D620C512000700FFFFFFC51200020FFDFFFFC512000200FFFFFFC51200050FFD0FFE4B
< OK
> DL36F620C20503482C01C20604743001C20306363101C20421FC3201FFFFFFFFFFFFFFFFC3
< OK
> DL371620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3
< OK
> DL373620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93
< OK
> DL375620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
< OK
> DL377620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53
< OK
> DL379620FFFFFFFFFFFFFFFFC51200070FFD0FFEC51200050FFD0FFEC51200030FFD0FFE3C
< OK
> DL37B620C51200020FFDFFFFC5120005320FFEC5120003320FFEC5120002320FFEC51200ED
< OK
> DL37D6200732FFFFFFFFFFFFC5120007000FFEC5120005000FFEC5120003000FFEC512000E
< OK
> DL37F6200200FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL381620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5120002000FFEC20101682D01C202039B
< OK
> DL383620112D01C20303483001C20406182F01C20506403101FFFFFFFFFFFFFFFFFFFFFFAA
< OK
> DL385620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72
< OK
> DL387620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52
< OK
> DL389620FFFFFFFFFFFFFFFFC51200051EFFFFFFC51200031EFFFFFFFFFFFFFFFFFFFFFF36
< OK
> DL38B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12
< OK
> DL38D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
< OK
> DL38F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
< OK
> DL391620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
< OK
> DL393620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
< OK
> DL395620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71
< OK
> DL397620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
< OK
> DL399620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
< OK
> DL39B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F0473058228017122
< OK
> DL39D62005C717BAD5FFFFFF4F0472058228017105C717BA46FFFFFF822802FFFFFFFFFFF5
< OK
> DL39F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1
< OK
> DL3A1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
< OK
> DL3A3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
< OK
> DL3A5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
< OK
> DL3A7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
< OK
> DL3A9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
< OK
> DL3AB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
< OK
> DL3AD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
< OK
> DL3AF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
< OK
> DL3B1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
< OK
> DL3B3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
< OK
> DL3B5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
< OK
> DL3B7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F
< OK
> DL3B9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F
< OK
> DL3BB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F
< OK
> DL3BD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF
< OK
> DL3BF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL3C1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE
< OK
> DL3C3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E
< OK
> DL3C5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
< OK
> DL3C7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E
< OK
> DL3C9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
< OK
> DL3CB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
< OK
> DL3CD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE
< OK
> DL3CF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE
< OK
> DL3D1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD
< OK
> DL3D3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
< OK
> DL3D5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D
< OK
> DL3D7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D
< OK
> DL3D9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
< OK
> DL3DB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D
< OK
> DL3DD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED
< OK
> DL3DF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
< OK
> DL3E1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC
< OK
> DL3E3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
< OK
> DL3E5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C
< OK
> DL3E7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C
< OK
> DL3E9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
< OK
> DL3EB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C
< OK
> DL3ED620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC
< OK
> DL3EF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC
< OK
> DL3F1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB
< OK
> DL3F3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B
< OK
> DL3F5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B
< OK
> DL3F7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
< OK
> DL3F9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B
< OK
> DL3FB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B
< OK
> DL3FD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
< OK
> DL3FF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB
< OK
> DL401620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
< OK
> DL403620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A
< OK
> DL405620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
< OK
> DL407620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A
< OK
> DL409620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A
< OK
> DL40B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A
< OK
> DL40D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA
< OK
> DL40F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA
< OK
> DL411620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9
< OK
> DL413620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89
< OK
> DL415620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
< OK
> DL417620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49
< OK
> DL419620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29
< OK
> DL41B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
< OK
> DL41D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9
< OK
> DL41F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9
< OK
> DL421620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8
< OK
> DL423620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88
< OK
> DL425620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68
< OK
> DL427620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48
< OK
> DL429620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
< OK
> DL42B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08
< OK
> DL42D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8
< OK
> DL42F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
< OK
> DL431620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7
< OK
> DL433620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
< OK
> DL435620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67
< OK
> DL437620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47
< OK
> DL439620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
< OK
> DL43B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07
< OK
> DL43D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7
< OK
> DL43F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7
< OK
> DL441620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6
< OK
> DL443620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86
< OK
> DL445620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66
< OK
> DL447620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
< OK
> DL449620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26
< OK
> DL44B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06
< OK
> DL44D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
< OK
> DL44F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6
< OK
> DL451620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
< OK
> DL453620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85
< OK
> DL455620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65
< OK
> DL457620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45
< OK
> DL459620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25
< OK
> DL45B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05
< OK
> DL45D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5
< OK
> DL45F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
< OK
> DL461620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4
< OK
> DL463620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84
< OK
> DL465620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
< OK
> DL467620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44
< OK
> DL469620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24
< OK
> DL46B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
< OK
> DL46D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4
< OK
> DL46F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4
< OK
> DL471620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3
< OK
> DL473620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83
< OK
> DL475620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63
< OK
> DL477620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43
< OK
> DL479620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
< OK
> DL47B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03
< OK
> DL47D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
< OK
> DL47F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
< OK
> DL481620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2
< OK
> DL483620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
< OK
> DL485620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62
< OK
> DL487620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42
< OK
> DL489620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
< OK
> DL48B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02
< OK
> DL48D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2
< OK
> DL48F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2
< OK
> DL491620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1
< OK
> DL493620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81
< OK
> DL495620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61
< OK
> DL497620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
< OK
> DL499620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21
< OK
> DL49B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01
< OK
> DL49D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
< OK
> DL49F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1
< OK
> DL4A1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
< OK
> DL4A3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
< OK
> DL4A5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
< OK
> DL4A7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
< OK
> DL4A9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20
< OK
> DL4AB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
< OK
> DL4AD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
< OK
> DL4AF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
< OK
> DL4B1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F
< OK
> DL4B3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F
< OK
> DL4B5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
< OK
> DL4B7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F
< OK
> DL4B9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
< OK
> DL4BB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
< OK
> DL4BD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF
< OK
> DL4BF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF
< OK
> DL4C1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E
< OK
> DL4C3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
< OK
> DL4C5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E
< OK
> DL4C7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E
< OK
> DL4C9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
< OK
> DL4CB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE
< OK
> DL4CD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
< OK
> DL4CF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
< OK
> DL4D1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D
< OK
> DL4D3618FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
< OK
> DL4D5620496E747275646572FFFFFFFFFFFFFFFF447572657373FFFFFFFFFFFFFFFFFFFF8C
< OK
> DL4D76204C696E65437574FFFFFFFFFFFFFFFFFF41726D4661696CFFFFFFFFFFFFFFFFFFDF
< OK
> DL4D96205A6F6E6554726F75626C65FFFFFFFFFF5A6F6E65416C657274FFFFFFFFFFFFFFFC
< OK
> DL4DB6204C6F7742617474657279FFFFFFFFFFFF506F7765724661696CFFFFFFFFFFFFFF54
< OK
> DL4DD62050616E6963FFFFFFFFFFFFFFFFFFFFFF456E747279416C657274FFFFFFFFFFFFD9
< OK
> DL4DF62054616D706572FFFFFFFFFFFFFFFFFFFF46697265FFFFFFFFFFFFFFFFFFFFFFFFC4
< OK
> DL4E1620476173FFFFFFFFFFFFFFFFFFFFFFFFFF46616D696C7943617265FFFFFFFFFFFF97
< OK
> DL4E3620506572696D65746572FFFFFFFFFFFFFF4279706173735A6F6E65FFFFFFFFFFFFAE
< OK
> DL4E562044697361726DFFFFFFFFFFFFFFFFFFFF434D5354657374FFFFFFFFFFFFFFFFFF6C
< OK
> DL4E762053797374656D41726D6564FFFFFFFFFF416C61726D41626F7274FFFFFFFFFFFFD4
< OK
> DL4E9620456E7472795761726E696E67FFFFFFFF536972656E54726F75626C65FFFFFFFF3E
< OK
> DL4EB620466F72636541726DFFFFFFFFFFFFFFFF5253343835436F6D6D73FFFFFFFFFFFF96
< OK
> DL4ED620446F6F7262656C6CFFFFFFFFFFFFFFFF486F6D6553616665FFFFFFFFFFFFFFFF91
< OK
> DL4EF6204469616C54657374FFFFFFFFFFFFFFFF534D5354726F75626C65FFFFFFFFFFFFC0
< OK
> DL4F16204E65774D657373616765FFFFFFFFFFFF456E67696E6565724469616CFFFFFFFFEF
< OK
> DL4F36205369676E696E54616D706572FFFFFFFF46726F6E74446F6F72FFFFFFFFFFFFFFF8
< OK
> DL4F56204261636B446F6F72FFFFFFFFFFFFFFFF4261636B476172616765446F6F72FFFFF4
< OK
> DL4F7620476172616765446F6F72FFFFFFFFFFFF476172616765504952FFFFFFFFFFFFFF1B
< OK
> DL4F9620436F6E7365727661746F7279446F6F72436F6E7365727661746F7279504952FF5F
< OK
> DL4FB6204C6F756E6765526F6F6D504952FFFFFF4B69746368656E504952FFFFFFFFFFFF41
< OK
> DL4FD620446F776E537461697248616C6C504952557073746169727348616C6C504952FFEE
< OK
> DL4FF6204D6173746572426564526F6F6D5049524D617374657242656450616E6963FFFF3C
< OK
> DL5016204775657374426564526F6F6DFFFFFFFF46726F6E74426564526F6F6DFFFFFFFF21
< OK
> DL5036204261636B426564526F6F6DFFFFFFFFFF5A6F6E653137FFFFFFFFFFFFFFFFFFFF4C
< OK
> DL5056205A6F6E653138FFFFFFFFFFFFFFFFFFFF5A6F6E65313930FFFFFFFFFFFFFFFFFF12
< OK
> DL5076205A6F6E653139FFFFFFFFFFFFFFFFFFFF447269766577617947617465FFFFFFFF56
< OK
> DL50962042726F6B656EFFFFFFFFFFFFFFFFFFFF466972655570737461697273FFFFFFFFC6
< OK
> DL50B62046697265476172616765FFFFFFFFFFFF5A6F6E653235FFFFFFFFFFFFFFFFFFFF1A
< OK
> DL50D6205A6F6E653236FFFFFFFFFFFFFFFFFFFF5A6F6E653237FFFFFFFFFFFFFFFFFFFFC5
< OK
> DL50F6205A6F6E653238FFFFFFFFFFFFFFFFFFFF5A6F6E653239FFFFFFFFFFFFFFFFFFFFA1
< OK
> DL5116205A6F6E653330FFFFFFFFFFFFFFFFFFFF5A6F6E653331FFFFFFFFFFFFFFFFFFFF8E
< OK
> DL5136205A6F6E653332FFFFFFFFFFFFFFFFFFFF5A6F6E653333FFFFFFFFFFFFFFFFFFFF6A
< OK
> DL5156205A6F6E653334FFFFFFFFFFFFFFFFFFFF5A6F6E653335FFFFFFFFFFFFFFFFFFFF46
< OK
> DL5176205A6F6E653336FFFFFFFFFFFFFFFFFFFF5A6F6E653337FFFFFFFFFFFFFFFFFFFF22
< OK
> DL5196205A6F6E653338FFFFFFFFFFFFFFFFFFFF5A6F6E653339FFFFFFFFFFFFFFFFFFFFFE
< OK
> DL51B6205A6F6E653430FFFFFFFFFFFFFFFFFFFF5A6F6E653431FFFFFFFFFFFFFFFFFFFFEC
< OK
> DL51D6205A6F6E65343230FFFFFFFFFFFFFFFFFF5A6F6E653433FFFFFFFFFFFFFFFFFFFF97
< OK
> DL51F6205A6F6E653434FFFFFFFFFFFFFFFFFFFF5A6F6E653435FFFFFFFFFFFFFFFFFFFFA4
< OK
> DL5216205A6F6E653436FFFFFFFFFFFFFFFFFFFF5A6F6E653437FFFFFFFFFFFFFFFFFFFF7F
< OK
> DL5236205A6F6E653438FFFFFFFFFFFFFFFFFFFF5A6F6E653439FFFFFFFFFFFFFFFFFFFF5B
< OK
> DL5256205A6F6E653530FFFFFFFFFFFFFFFFFFFF5A6F6E653531FFFFFFFFFFFFFFFFFFFF49
< OK
> DL5276205A6F6E653532FFFFFFFFFFFFFFFFFFFF5A6F6E653533FFFFFFFFFFFFFFFFFFFF25
< OK
> DL5296205A6F6E653534FFFFFFFFFFFFFFFFFFFF5A6F6E653535FFFFFFFFFFFFFFFFFFFF01
< OK
> DL52B6205A6F6E653536FFFFFFFFFFFFFFFFFFFF5A6F6E653537FFFFFFFFFFFFFFFFFFFFDD
< OK
> DL52D6205A6F6E653538FFFFFFFFFFFFFFFFFFFF5A6F6E653539FFFFFFFFFFFFFFFFFFFFB9
< OK
> DL52F6205A6F6E653630FFFFFFFFFFFFFFFFFFFF5A6F6E653631FFFFFFFFFFFFFFFFFFFFA7
< OK
> DL5316205A6F6E653632FFFFFFFFFFFFFFFFFFFF5A6F6E653633FFFFFFFFFFFFFFFFFFFF82
< OK
> DL5336105A6F6E653634FFFFFFFFFFFFFFFFFFFF6B
< OK
> DL5746205521FFFF45FFFFFF20FFFFFF1BFFFFFF2506FFFF17BAFFFFFFFFFFFFFFFFFFFF68
< OK
> DL576620FFFFFFFFFFFFFFFF17BAFFFF12C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95
< OK
> DL578620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
< OK
> DL57A620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03
< OK
> DL57C620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
< OK
> DL57E620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
< OK
> DL580620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2
< OK
> DL582610FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
< OK
> DL588620D4FFFF4A01D3FFFF520153FFFF4E01FFFFFF0000FFFFFF0000FFFFFF0000FFFF2C
< OK
> DL58A620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000051D4FF320151D3FF3342
< OK
> DL58C620015153A52901FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF5E
< OK
> DL58E620FFFF0000FFFFFF0000FFFFFF000051D4FF2D0151D3FF2C015153A56B01FFFFFF56
< OK
> DL5906200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000093
< OK
> DL592620FFFFFF00003951D42E013951D32F015153A56A01FFFFFF0000FFFFFF0000FFFF9E
< OK
> DL594620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000051D4FF30FD
< OK
> DL5966200151D3FF31015153A50000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF8F
< OK
> DL598620FFFF0000FFFFFF0000FFFFFF0000FFFFFF000017BAFF900112C7FF9201FFFFFF43
< OK
> DL59A6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000F3
< OK
> DL59C620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFD5
> DL59E620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00B4
< OK
< OK
> DL5A062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF93
< OK
> DL5A2620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF74
< OK
> DL5A46200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000052
< OK
> DL5A6620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF34
< OK
> DL5A8620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0013
< OK
> DL5AA62000FFFFFF0000D5FFFF900146FFFF9201FFFFFF0000FFFFFF0000FFFFFF0000FFB2
< OK
> DL5AC620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000D5AF4607
< OK
> DL5AE6209401FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00001D
< OK
> DL5B0620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF93
< OK
> DL5B2620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0072
< OK
> DL5B462000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF52
< OK
> DL5B6620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF33
< OK
> DL5B86200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000011
< OK
> DL5BA620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFF3
< OK
> DL5BC620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00D2
< OK
> DL5BE62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFB2
< OK
> DL5C0620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF92
< OK
> DL5C26200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000070
< OK
> DL5C4620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF52
< OK
> DL5C6620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0031
< OK
> DL5C862000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF11
< OK
> DL5CA620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFF2
< OK
> DL5CC6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000D0
< OK
> DL5CE620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFB2
< OK
> DL5D0620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0090
< OK
> DL5D262000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF70
< OK
> DL5D4620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF51
< OK
> DL5D66200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00002F
< OK
> DL5D8620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF11
< OK
> DL5DA620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00F0
< OK
> DL5DC62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFD0
< OK
> DL5DE620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFB1
< OK
> DL5E06200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00008E
< OK
> DL5E2620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF70
< OK
> DL5E4620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF004F
< OK
> DL5E662000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF2F
< OK
> DL5E8620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF10
< OK
> DL5EA6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000EE
< OK
> DL5EC620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFD0
< OK
> DL5EE620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00AF
< OK
> DL5F062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF8E
< OK
> DL5F2620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF6F
< OK
> DL5F46200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00004D
< OK
> DL5F6620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF2F
< OK
> DL5F8620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000E
< OK
> DL5FA62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFEE
< OK
> DL5FC620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFCF
< OK
> DL5FE6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000AD
< OK
> DL600620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF8E
< OK
> DL602620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF006D
< OK
> DL60462000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF4D
< OK
> DL606620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF2E
< OK
> DL6086200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00000C
< OK
> DL60A620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFEE
< OK
> DL60C620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00CD
< OK
> DL60E62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFAD
< OK
> DL610620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF8D
< OK
> DL6126200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00006B
< OK
> DL614620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF4D
< OK
> DL616620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF002C
< OK
> DL61862000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF0C
< OK
> DL61A620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFED
< OK
> DL61C6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000CB
< OK
> DL61E620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFAD
< OK
> DL620620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF008B
< OK
> DL62262000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF6B
< OK
> DL624620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF4C
< OK
> DL6266200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00002A
< OK
> DL628620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF0C
< OK
> DL62A620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00EB
< OK
> DL62C62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFCB
< OK
> DL62E620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFAC
< OK
> DL6306200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000089
< OK
> DL632620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF6B
< OK
> DL634620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF004A
< OK
> DL63662000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF2A
< OK
> DL638620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0B
< OK
> DL63A6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000E9
< OK
> DL63C620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFCB
< OK
> DL63E620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00AA
< OK
> DL64062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF89
< OK
> DL642620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF6A
< OK
> DL6446200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000048
< OK
> DL646620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF2A
< OK
> DL648620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0009
< OK
> DL64A62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFE9
< OK
> DL64C620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFCA
< OK
> DL64E6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000A8
< OK
> DL650620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF89
< OK
[size=3][font=Calibri]> DL652620FF000
The last log seems to indicate that the write operation was completed and Comfigurator reset the system
[size=\"3\"][font=\"Calibri\"]> DL6A96205807551507085315130853151708561560032531071025310732FFFFFFFFFFFF3A[/font][/size]
[size=\"3\"][font=\"Calibri\"]< OK[/font][/size]
[size=\"3\"][font=\"Calibri\"]> DL6AB601FFE0[/font][/size]
[size=\"3\"][font=\"Calibri\"]> RS[/font][/size]
[size=\"3\"][font=\"Calibri\"]> LI[/font][/size]
[size=\"3\"][font=\"Calibri\"]< LU00[/font][/size]
What was the problem
What are you trying to do below?
[size=\"3\"][font=\"Calibri\"]UB01010A[/font][/size] is upgrading UCM Firmware using the programming cable. Why are you attempting to do this?
[size=\"3\"][font=\"Calibri\"][/font][/size]
[size=\"3\"][font=\"Calibri\"]> LI****[/font][/size]
[size=\"3\"][font=\"Calibri\"]> UL000003[/font][/size]
[size=\"3\"][font=\"Calibri\"]> V?[/font][/size]
[size=\"3\"][font=\"Calibri\"]> v?[/font][/size]
[size=\"3\"][font=\"Calibri\"]> U?[/font][/size]
[size=\"3\"][font=\"Calibri\"]< LU02[/font][/size]
[size=\"3\"][font=\"Calibri\"]< DL00000305FF22D7[/font][/size]
[size=\"3\"][font=\"Calibri\"]< V?FE060522200100[/font][/size]
[size=\"3\"][font=\"Calibri\"]< v?05FF23010203FFFF[/font][/size]
[size=\"3\"][font=\"Calibri\"]< U?0A060211[/font][/size]
[size=\"3\"][font=\"Calibri\"]> UB01010A[/font][/size]
[size=\"3\"][font=\"Calibri\"]< Z?00010000[/font][/size]
Hi Ident
I was just trying to do actions to talk to the system to see if it failed to communicate. I did a lot of system info requests as well and uploaded a config change.
I have alway intended upgrading the ETH UCM to 6008 from 6002 to see if this makes the ETH comms more stable and though I could do this by selecting upgrade firmware. When I tried it says update failed with errors.
I might be over complicating this, but the  basics are either using a xover cable or on my network I seem to loose comms which requires a reset on the ETH UCM board.
When I was in the US the iPhone app worked great for a couple of weeks, but then lost comms altogether ETH reset sorted. If I use comfigurator I seem to loose comms a lot sooner guaranteed within 24hrs. This is when I am making config changes as I learn more about the programming.
I really appreciate your help.
Lee
