For full details, refer to the UCM/CBUS Manual from https://www.cytech.biz/ucmcbus2_manual.html
small.jpg)
Specifications
The following equipment is required
small.jpg)
Specifications
- Size 108 x 88 mmm UCM baseboard with C-BUS SIM (Serial Interface Module) daughterboard.
- Power Supply: 12V 30 mA (supplied from Comfort)
- Connected to C-BUS via bus cable (2 wires). Comfort is electrically isolated from C-Bus.
- Supports Lighting, Security, Clocks/Timekeeping, Enable, Trigger, Measurement Applications
- Synchronizes the date and time between Comfort and C-BUS via the Time/Date Application.
- Comfort implements the C-Bus Security application. Comfort automatically sends Alarm information which can be displayed on C-Touch. The following status messages are supported: Armed/disarmed, Exit Delay Started, Entry Delay Started, Alarm Active, Tamper active/Inactive, Panic Active, Battery Status, Status Reports 1 & 2. The following Security Control messages are supported: Arm system, Activate/deactivate Tamper, Activate Panic, Emulate Keypad, Status 1 and 2 Request.
- C-Touch can simulate a keypad allowing entry of user code and arming/disarming of Comfort.
- Maps Cbus group addresses in supported applications to Comfort Counters, sensors, Flags, Virtual Inputs, Physical Inputs, Outputs
- UCM /C-Bus2 Module with firmware version UCM/C-Bus2 version 7.045 or above.
- Comfort firmware Version 7.xxx
- UCM/USB or ETH firmware version 7.xxx
- UCM/CBus2 Firmware 7.042 (Beta)
- Comfigurator 3.8.5 or above. Download from https://www.cytech.biz/comfigurator.html
