04-14-2012, 02:51 PM
I just upgraded an existing UCM from RS232 to ethernet by adding an ETH01 module, yet no matter what I do I cannot get Comfigurator to do anything other than say \"No Response from UCM\"... Here\'s what I\'ve done so far...
Starting point is a 100% funtioning system, 3 UCMS, all working, no comms errors reported etc.
UCM ID1 Comfort to Homeseer for monitoring & control
UCM ID2 = CBUS
UCM ID3 = Comfort to Comfigurator for programming. (formerly RS232, now ETH)
As mentioned, all working perfectly..
I plugged on the ETH01 module to UCM 3 (observed lights coming on)
I jumpered SW8-F
I connected the Ethernet port to my network switch
I installed & Ran DS Manager, it discovered the module no problem
I set the IP, Netmask, Gateway, and all other parameters as per UCM Manual
I can now PING the IP address of the UCM/Ethernet (I couldn\'t before)
I Ran Comfigurator - Options > Settings, and changed UCM Interface setting to Network, and set the IP to the UCM IP as just set in DS Manager
That, I believe, is all that should be required? - No changes to the number of modules or anything, since the number of UCMs is the same...
Comfigurator however, will not connect... I\'ve tried resetting the UCM several times, I tried REMOVING SW8-A & SW8-B (no difference). Nothing I do will illicit a connection from comfigurator to the UCM/ETH
Any thoughts?
UCM is running 5.156 I believe... (according to sticker on the chip)
Paul G.
UCM ID2 = CBUS
I jumpered SW8-F
Any thoughts?
Paul G.
