Threads: 20
My door stations have suddenly stopped chiming on the keypads
The phone rings, but I liked the keypads chiming too (as its quicker than waiting for phone to ring
I have DP03x - any ideas why this might be?
Threads: 476
is the chime on the door stations?
Check the Siren Type > Doorbell and see if the \"keypad\" box is checked
Threads: 20
yes - the keypads box is checked - so I just can\'t see why the keypads would not chime
could the DM02 PCB be damaged in some way? - only reason I can think of as it suddenly stopped doing it without any warning....I don\'t recall changing any settings.
Threads: 476
The DM02 must be working otherwise the phones will not ring when the doorbel is pressed.
If the phones can ring the keypad should be able to chime. It should be a configuration setting
Try writing a default template into your system and add just one DP and KP and try the doorbell again
Threads: 20
can I send you my cclx file - perhaps you\'ll be able to see which setting it is?
One odd thing I have noticed - when I write to Comfort via WIFI / CWM, or read from comfort using wifi / cwm, sometimes it writes/ reads incorrectly - so what comfirgurator tells me is in Comfort is wrong...especially for tuning parameters.....is this a known error?
Threads: 476
Yes please send to support@cytech.biz
Comfigurator reading/writing incorrectly is not a known error. How does it write incorrectly ? Please provide more detail
