03-24-2013, 06:00 AM
This forum is for support of the new Comfort iPad App.
PDF Instructions can be downloaded from https://www.cytech.biz/comfort_ipad_app.html
Comfort for iPad app is on iTunes at this link https://itunes.apple.com/sg/app/cytech-c...04532?mt=8 or on your iPad search for Cytech Comfort and choose the iPad app NOT the separate iPhone app
Minimum firmware is Comfort and UCM version 7.xxx
Setup
Install the Comfort app on your ipad. Search for Cytech Comfort on iTunes, and select the iPad and not the separate iPhone app
You will need to upload the cclx file used to program the Comfort system to the Cytech server. This converts the cclx file to a format that can be used in the iPad.
Go to https://www.cytech.biz/crl_comfort_app_convertor.php
Enter your name, an email that can be opened on your iPad, and browse for the cclx file.
Select iPad/Android. Click ââ¬ÅUpload Fileââ¬Â
Go you your iPad and open your email client. DO NOT use webmail by browser - that will NOT work.
Look for the email titled ââ¬ÅComfort Conversion Serviceââ¬Â
Tap on the attachment which should be a .jcrlccip file.
A message appears with options to select which app to open in
Select ââ¬ÅOpen in Comfort4iPadââ¬Â
The next screen gives an option to select one of the configurations in the iPad app. ââ¬ÅHomeââ¬Â and
ââ¬ÅOfficeââ¬Â are available by default. Multiple configurations allow you to control several Comforts.
Select any unused config.
Open the app if it does not automatically open
Continued in the next post
To go to the Control Page swipe to the right
