Firmware upgrade for Comfort II SPC?
I have a Comfort II SPC . I\'m from portugal. Current my version of firmware is 6.011 file system 30, vocabulary 11, UCM Type 10 , UCM Version 6.008
I want to know if there is any update available for my central.
Many thanks
Nuno
SPC Firmware currently is at 7.032
UCM Firmware is 7.028
You can automatically upgrade any Comfort or UCM, KP06 or KT03 firmware using Comfigurator 3.7.6 when you are connected to the Internet
Do Scan for all modules, then the current and latest firmware will be shown as below
To Upgrade to the latest firmware right click on the module and select \"Check for firmware Updates\"
The firmware will be upgraded from the server
You will be asked to press F0 on the keypad
Please see the instructions on Upgrading firmware on the forum
http://www.comfortforums.com/forum92/3400.html
You should upgrade your UCM to the lalest firmware v7 before your comfort SPC
To avoid missing any announcements that may be important to you, I suggest to go to  the Forum Menu > My Account > Watched Forums and check the forums that you want tp watch. The posts that you select will be forwarded to you either as daily digest or individual emails as you choose
Thanks for your prompness on this.
Ok,
I have to to the update then.
One more question, if i upgrade the UCM and the Comfort and the UCM to the latest version, will i loose the vocab and the settings from the system including the sentences?
How can i backup that inforamtion if i don\'t have the file of vocab and the sentences?
The vendor did not give to me the file that files, only the files of the cclx..
Upgrading firmware should not affect the voice or sentences
If you have any problem let us know
ok, many thanks for the info.
when i arrive home i\'ll do 1st the UCM upgrade and then the Comfort , and feed back you.
HI
I did succesefully the upgrade on Comfort and on UCM, but when i do the scan for all modules, it appear the error that is in the picture.
After the error appear, i cannot do anything more, the error is allways appearing.
And how can i update the RIO firmware and the keypad? because it appear that i need another version to update from web (image attached with the versions)
I alredy removed and installed cytech software.
Error Scan Modules
RIO Info
Can you do the scan and in Monitor I/O do Copy to Clipboard and send the whole contents
Are you using Comfigurator 3.7.6?
RIO and SCS, KP03, KP044, KP05, DP cannot be upgraded by this method
I\'ve just made some tests after i arrive home and i noticed that i don\'t have some things working besides that error..
The output that was working that was the curtains up and down, is not working. only works on the physical press button. and other issues that i explain better with logs and .jpg atached in a document that i did.
please find out the .docx in the post with the config files and I/O monitor.
i send to you a private message with the password of the zip file.
i would be really appreciated if you can help me solving this.
many thanks
regards
Nuno
.zip   Cytech Nuno Bexiga.zip (Size: 586.04 KB / Downloads: 3)
