Known Issues
New Changes
- Actions Add counter, Add counter give wrong answer from 7.039
- the conditional action If Night Time does not work. To work around, go to Keypad Location Menu in Engineer Menu 7,41, enter 374#, system announces Location 374, enter new number and # key. Enter 64#. This assigns flag 64 to the night time flag.
- The Flag 64 mapped to the Night Time Flag between Sunset and Sunrise is broadcast every minute even if he flag is unchanged. This causes UCM/Ethernet if logged in to remain logged in even if the programmed idle time (default 2 minutes) times out and prevents other connections from logging in (eg from iphone/ipad apps). This has an effect only for UCM/ETH
New Changes
- The night time flag will not be mapped to Flag 64. Instead there will be a location setting in Comfigurator which can assign the Night Flag to any flag. This changes the operation of the Night Time Flag in Comfigurator. The Get Night time will not work the same way
- Set and Clear Flag commands wil be broadcast only if the flag state is changed. This fixes the bug in 7.045
