Threads: 8
I have last Eth2 firmware version.
Having Homeseer 2 and trying the pjccomfort plugin (which is not so far), I am checking my config with Tibbo DS manager. I can see the blue icon and my device set up at the right ip address, but mostly of the time, checking the settings give me an error message \" no response from this device\", while at the same time I can connect with Wizcomfort without a single problem.
Any idea?
Is anyone running HS and the pjc plugIn?
Thank you
Philippe
Threads: 4
Who made the pjcomfort plug in? Can you get support from their techsupport?
Threads: 8
Sure easy to find, I contacted him but no answer, hence my search for potential users.Thanks
Threads: 8
01-06-2014, 07:15 AM
(This post was last modified: 01-06-2014, 07:47 AM by ident.)
But for now, I \'d like to solve my DS mabager problem first.
Tried with the blast version of DSmanager, but my Eth2 device is still not found. The firewall is off and my eth2 is on the same bridge where is my pc.
But again, wiz comfort still able to work with eth2!
Threads: 8
I tried again this sequence. No Change.
Explorer was ble to find the eth2, but this time the IP adress was wrong (1.0.0.1).
I downloaded the firmware 3.13 again , the eth2 rebooted and explorer shown eth2 with the right IP address. With DS manager, Eth2 is also appearing with the blue icon, but when I try to check the settings, a red arrow appears in front of the device, and I got an error message saying \"no response from this device\" , but wizcomfort is still communicating with comfort!
Threads: 476
Can you show the screenshot with the error message?
If wizcomfort and Comfigurator are working with the ETH02 then there should be no problem with it although we do not know why you get the error.
I suggest using another PC with DS Manager and see if you see the same thing
Threads: 8
Just sent via email the screenshots.
Threads: 8
Email did not work, how to send them?
