my system is Cytech ultra2 with firmware upgraded to 7.047 and UCM/USB board PC01-066A.I replaced daughter board with Eth02 board PC01-090A firmware 3.03. UCB firmware upgraded to 7.028.
shunt F at SW8 closed ( i tried both cloth and open)
the problem is : Ethernet is not discoverable neither with device Explorer nor DS manager.Firewall is off i tried to reset the firmware through SW1 procedure as described in manual but with no result.
the led status is as follow:
- D101 steady when the cable inside (low flashing every 15 sec)
- left led at RJ45(close to D101) steady on, Right side led steady off
- D10 is steady green ( very speed flashing)D9 is flashing (noticeable)
- D1 is on Green , and (D2+D3+D4) IS OFF
