08-22-2014, 01:59 PM
I am using CBUS2 (version 7.054) and it is truly remarkable.
Would it be possible to change the UI to allow installers to specify which CBUS group address they would like to add to the Lighting Section? If I click on Add Group Address, the UI determines first GA that is not in the table and adds that (for example I do not use GA 0, so it will add that first). I set-up my groups with future expansion in mind, so there are GA that I do not use for now, and every time I want to add a new GA, the UI tries to fill gaps first, which means I have to delete those that I do not once it reaches the GA I want, or I would need to change the project file manually (which is what I have been doing).
I have a question about the Physical Inputs. Currently you cannot add or delete them, which means unused inputs will show up as having references with a blue foreground. Would it be possible to either remove the references or maybe allow installers to specify the inputs they would like to use?
One last question. There are conditions in which Comfort will send all the input statuses to CBUS. Would it be possible to either allow installers to specify which inputs, or have a logical condition check which only sends the inputs that are actually used/referenced?
