Hi Mr Evard, I think there are 3 steps you need to do to achieve that.
1. In Comfigurator, go to \"Events\">>\"Miscellaneous Events\", then create a response like below for \"Start Arming Response\".
The response is to Bypass the PIR Zone first, then 5 minutes later, unbypass it.
To create this response, firstly,you may click \"Appendãâ¬â¬new action\">>\"Input\">>\"Bypass Zone\", then on the right panel, select the PIR Zone. Secondly, click \"Append new action\">>\"Do\">>\"Do response after timer expires\", then on the right panel, you need to select the delay, timer, and choose the response which unbypass PIR, the response to unbypass is to click \"Append New Action\">>\"Input\">>\"Unbypass Zone\", then select the PIR Zone.
2. Create a response to Unbypass PIR for \"Security Off Response\"(shown below)
This response is to unbypass PIR Zone immediately when you disarm the system, otherwise you have to wait for 5 minutes to get PIR back to work if you disarm the system during this 5 minutes period.
3. In Comfigurator, go to \"Security\">>\"Zones/Inputs\", set the PIR Zone as \"Switch NC\", the create a response for \"On Response\" shown below
This response is to play a short chime when PIR triggered, if it is during night time, it will turn on light, then 5 minutes later it will turn off automatically, keep triggering PIR will restart the timer.
To create this response, firstly,you need to click \"Append new action\">>\"Output\">>\"Activate Siren\", then select Chime on right panel.
secondly, you need to click \"Append new action\">>\"if\">>\"Add Condition\", select \"Night Time\" in Attribute and select \"<>0\" in Comparison. Lastly, to turn on light and off light 5 minutes later, then move up those two codes into if loop. In the picture below, switch on/off output 1 is an example only, to simulate light on/off.
