Comfort Firmware 7.160
Known Bugs
Known Bugs
- Force arm on partition using # key does not work always send to partition 0
- Partitions do not work well with UCM log in with ETH03
- CT counter report ââ¬â if counter response changes another counter value, the counter report for the changed counter has the same conter id as the original. So if KNX sends a counter update, counter response change another counter and the counter is reported to knx, the counter id remains as KNX ucm id so the KNX ignores the new counter report.
- Upgrade CM9001 by ETH03 plug in. If reset occurs while upgrade, set baud rate for eth03 is not done.
- query_serialno bug in self id ââ¬â sent serial no of Rs485 wrong. Broadcast serial no at reset instead of send serial no queries to id
- Doorphone action 9 partition 1 spkr/mic are turned on for doorphone intercom instead of doorphone ID
- From 7.159 increment counter, decrement counter actions did not return counter value as last action value so If action which follows uses the wrong value
- Fixed BUG For Partition Systems trouble alarms are registered into random partition and Restore may be registered to different partition so cannot acknowledge
- Action 160 - switch S12V off time if time = 0, dont start timer for on time
- Action 159, 0, 3 Convert 256 to 100 use fractional value and round off
- Actions subtract parameters for Action 149, 3 (immediate), 149, 4 (counter), 149, 5 (sensor)
- Eventlog - command E?FF last event Fixed BUG did not work
- For EMS sensor event log, if module which reported sensor has Communications Failure, set sensor value to 255 so KP04A display does not remain unchannged as last value reported, and causes alarm
- If there is no partition 0, trouble alarms report in lowest partition
- For partition system turn off all keypad speakers first so only partition keypad can hear siren sound and announcement
- KP06A Keypad volume has max 100. KP06A volume is actually divided by 2
- If an SMS dialout fails, immediately go to the next dial without time out delay
- The Counter Response is also activated when Comfort changes a Counter value. Eg by Responses/ Action codes or Control menu. Previously, Counter Response is avtivated only when the counter us changed by a UCM
- Support Fractional Values for KP04A display
- Implemented Sensor calibration with Fractional value 1/16 for EMS
- Sensors adjustment for scale fix bug for division
- For EMS sensor event log, fixed BUG that sensors 9 onwards are not recorded correctly. Changed so that any sensor with counter assigned is recorded in event log every hour
- Sensor Register calibration in eepron is 1/16 units to use calibration value with 1/16 unit calibration value from eeprom
- ETH03 plug in support UN command
- s? s! Comands retiurn 3rd byte
- For plug in eth03 for LGX, UCM/LOG, CM9001, Sensor, Counter, Flag command will echo state eg C! Will report CT
- No of Responses number from 1024 to 512 affect ucm/log, knx/logic
- Removed x10 responses not used affect knx/logic and ucm/logic
- KNX/Logic saved nonvolatile counters increased from 8 to 32
