UCM
Hi,Since upgrading comfigurator to version 3.13.3.0 a few weeks ago i cannot connect to the UCM when i search for modules. I have checked the settings and IP addresses are all correct and the comfort server manager sees the UCM[size=\"1\"].[/size][size=\"2\"] Any ideas?????[/size]Ray
Please check if the D9 red and D10 green leds on the UCM baseboard are blinking which shows the UCM is being polled by Cofort
I still get this intermittently.
Yes both led are flashing.
do you have ETH02 or ETH03? What is your ucm firmware?
I installed an ETH03 after the last fault and the firmware version is 7.119.
Ray
Please check comfort server manager status.Can you see the eth03 ipaddress in the window?
Yes it address is OK and it is blue.
In CS Manager the state is idle if there is no connectionWhen you try to connect, it should change to Busy. Can you check that. Also for the 2nd portOf it is busy then the PC has managed to connect..
Have you tried another pc?
Hi,System stays in IDLE state all the time.Don\'t have another PC to try this on.Ray
Users browsing this thread: 4 Guest(s)
