Comfort Firmware 7.183 to 7.202
[size=\"3\"][size=\"2\"]Firmware 7.183
[/size][/size][size=\"3\"][size=\"2\"]Known Bugs[/size][/size]
  • [size=\"2\"]Action 1 (Announce Zone Name) in Zone Off Response will skip announcing the 1st word in the zone[/size]
[size=\"3\"][size=\"2\"]Bugs Fixed[/size][/size][size=\"3\"] [/size]
  • [size=\"2\"]Fixed BUG for eth03 plug in to CM9001 - UL with 2 bytes always returns the 2 same bytes[/size]
  • [size=\"2\"]Event Log  fixed BUG last event 27 was 68 may  cause event log to crash from 28/6/18 [/size]
  • [size=\"2\"]Fix BUG for partitions arm to away sometimes dis not work[/size]
  • [size=\"2\"]Fix bug from 13/6/19 Security check may use wrong partition [/size]
  • [size=\"2\"]Fix bug  from 6/3/20 if log in wrong code using ext232 there is no reply LU00, comfigurator waits and times out[/size]
  • [size=\"2\"]Fix Bug  Monitor Mode MO00 cannot exit from monitor mode[/size]
  • [size=\"2\"]Fixed bug Monitor Mode MO00 cannot exit from monitor mode [/size]
  • [size=\"2\"]Fixed Bug Action 158 clear and set counter did not work, but toggle worked [/size]
  • [size=\"2\"]Fixed BUG dR report was not sent when ETH03/Wifi01 was plug in on CM9001[/size]
  • [size=\"2\"]Event Log  fixed BUG last event number was wrong, may   cause event log to crash from 28/6/18 [/size]
[size=\"2\"]Event Log[/size]
  • [size=\"2\"]Change in Event Log indexing. Reduces Wear on the EEPROM due to writing the event log pointer with every event. Also reduces time to erase the whole event log Fixed other bugs[/size]
  • [size=\"2\"]Event Log will not announce month 0 if it is encountered[/size]
[size=\"2\"]Action Codes[/size]
  • [size=\"2\"]Action 162 Assign Reminder to Alarm to assign a recorded reminder message to an Alarm to replace sentence. If no the assigned Reminder number is recorded, the alarm message will be played[/size]
  • [size=\"2\"]Action 163 assign reminder no to zone. if zone has reminder message, it will play the reminder message in event log,  zone announcement and security check, but zone menu will continue to play the zone words. If the Reminder is assigned to a zone, but the reminder message is not recorded, the zone words are played[/size]
  • [size=\"2\"]Added Action get parameter  61 Login Partition[/size]
[size=\"2\"]Partitions/Areas[/size]
  • [size=\"2\"]Partitions If all keypads are in partition 0, allow parttions to be enabled.  some systems disarm by switch[/size]
  • [size=\"2\"]Announce  Area/Partition  number in user menu if partitions exist[/size]
  • [size=\"2\"]For partitioned system,  arm and disarm security will announce Area (Partition) Number after announcing security mode. Requires Vocab version 42[/size]
[size=\"2\"]Announcements[/size]
  • [size=\"2\"]Dial out announcements -   changed order for dial out alarm announcements. 1st play recorded alarm message, then alarm type, then alarm pararameter announcement[/size]
  • [size=\"2\"]Vocabulary version 42 sentence 87 is Area (N)[/size]
  • [size=\"2\"]Detector_announcement -  if not trouble or restore, announce reminder call detector_name so reminder can be announced  detector_announce if restore zone but no words in zone, call say_zoneNrestore. require vocab v43[/size]
  • [size=\"2\"]Voice menu add 8 for zone announce Require vocab 43[/size]
  • [size=\"2\"]zone restore announcement -  zone name restore instead of just Restore without zone[/size]
Environmental Monotoring System CM9001-EMS
  • E[size=\"2\"]MS enable reminders for zones and alarms. disable Scheduled Remimders for EMS for play reminder action only[/size]
  • [size=\"2\"]Enabled 16 Reminders  for ems[/size]
  • [size=\"2\"]Allow  Ems without Incoming recorded messages,  with Reminders in Responses[/size]
  • [size=\"2\"]EMS Voice menu  add 5 for  reminder messages f[/size]
  • [size=\"2\"]EMS sensors fix bug sensor - setpoint comparison was unsigned, ie negative values are taken as positive.  process_sensortab fix bug counter compare with max and min setpoints was unsiged should be signed.[/size]
  • [size=\"2\"]EMS sensors.mac process_sensortab limit counter setpoint to -128 to 127. fix bug counter >255 was set to 255 ie -1[/size]
  • [size=\"2\"]EMS Sensor Setpoint Counter prevent max/min setpoint check from doing endless loop
    [/size]
  • [size=\"2\"]EMS sensors - adjust_sensor limit final sensor values to -128 to + 127 after adjustment, but allow signed 16 bits intermediate. Aallowed sensor values for scaling (;1 = 0 to 99. sensor 0 to 255,   2 = multiply by scale factor. sensor -128 to + 127, 3 = divide by scale factor, sensor -32768 to 32767. allow larger range for division. final value will be -128 to + 127[/size]
[size=\"2\"]Misc[/size]
  • [size=\"2\"]Motion sensor Timer enabled for EMS. query d? got reply NA before[/size]
  • [size=\"2\"]For wifi NTP, update time daily at 12: 05 am instead of 4 AM[/size]
Bug in 7.183
Firmware 7.185 (Beta)
  • Fix bug from 25/5/20 zone restore action 1 when zone restored, 1st word in zone is skipped,
  • Fixed Bug In partitioned system, siren sounds for arming wer not  heard on the partition keypad
  • Fixed Old bug - if there is zone trouble in a partitioned system at reset, the partition keypad will show \"Communications Failure\"  without ID (instead of zone trouble)- Fixed Old Bug - if zone trouble is force armed when armed, after disarmed, the zone trouble is not shown until armed again or security check
  • Fixed Bug for Wifi Plug in, if if  not logged in or  does not log out,  idle timer from EEPROM expires does not reset Wifi module. so if wifi lost connection, the module is not reset
  • Fixed Old Bug Igf there s zone trouble and security is force armed, after disarming, the zone trouble is not shown anymore untill system is armed or security check
  • Fixed old bug in Partitioned system after alarm sren times out, the alarm state does not go to alert state. This caused after arm fail, not able to arm
  • Fixed old bug SMS disarm could not disarm from arm fail
Bugs
  • For Partitioned systme, when user logs in for partition >0, every minute the partition may be changed to to 0 so the user may arm or disarm to partition 0
Please download the beta firmware from https://www.cytech.biz/comfort_ultra_firmware.html
Firmware 7.187
Bugs Fixed
  • Fixed Bug in CM9001 Main Board for virtual Input 1 to 8 did not waork correctly
  • Fixed bug for partitions – when user in partition > 0 signs in sometimes the partition getrs set to 0 at the start of each minute (by vacation mode check)
Firmware 7.192
Known Issues
  1. Digital Zone type on CM9001/SEM . If zone is Digital Normally open, Off zone is  reported as ON. also for non digital zone, trouble Short Circuit  reports as Open circuit. This is an old bug affecting previous firmware
  2. Keypad to Door Station Intercom does not work. KP cannot hear DP
Bugs Fixed
  1. Fixed Bug If firmware upgrade failed and  power off and, firmware upgrade from UCM ID1 did not work
  2. Fixed bug ultra cannot upgrade to EX by ETH03 plug in
  3. FIXED BUG . UCM/LOG and KNX/LOG did not work for RIO
  4. Fixed BUG eth03 plug in did not report RIO Input state change
  5. Fixed BUG  vacation mode for partition system  did not set partition correctly
  6. Fixed BUG If no zones in partition 0, cannot arm partition 0 without zones. exit time does not end
  7. Fixed BUG for ETH03 plug in   ST command reply did not work
New Features and Changes
  1.  When Sign in on Phone : check if user who log in is enabled for higher partitions, and say \"select Area\". check if user is enabled for higher partition, and if so log in to the higher Area/partition.
  2. For Arm security system, if area/partition has no zones arm/disarm is not enabled.
  3. Keypad to Door Station Intercom. Keypad Press and hold button is one way KP to DP. If KP button is released then KP to DP is full duplex
  4. If IDBUTTON on CM9001 is pressed and held at reset, disable Responses This allows system to work even when there are responses with endless loop, ie Responses calling themselves, or problems in the Startup Response.
  5. Added Test mode commands to support production tester functions
Firmware 7.193 (Beta)
  1. Fixed old BUG-  Digital Zone type on CM9001/SEM . If zone is Digital Normally open, Off zone is  reported as ON. also for non digital zone, trouble Short Circuit  reports as Open circuit. This is an old bug affecting previous firmware
  2. For CM9001-EMS Event Log  Sensors with value = 0 do not report in the event log every hour to avoid filling up the event log
Known Bugs
  1. For Keypad to Door Station Intercom, Keypad cannot hear the Dooor station
I am currently on firmware 7.183 on II Ultra.
Comfigurator version 3.13.7.0.
Comfigurator tells me there is a firmware update to 7.192. When I say yes to upgrade nothing happens.
Any idea why that might be?
(I know I can do it manually but would prefer to do it automatically)
That worked, thank you.
A Bug has been discovered with ULT 7.192 and 7.193 when using the Keypad to Door Station intercom. The Door station cannot be heard in the Keypad. A firmware upgrade will be released soon to fix it
Firmware 7.194
Bugs Fixed
  1. Fixed Bug from 7.192 - Keypad to Door station Intercom was 1 way only. KP could not hear DP
Those who use the Door station, please upgrade the firmware
BUG in OPT 7.194
OPT 7.194 may have reset problem - cannot start up
