Comfort Firmware 7.213
Known Bugs
  1. Responses to send commands to Cbus and KNX using send text (action 197) will not be terminated, but continue to the next numeric Response, causing unexpected effects. This will be fixed in the next version
  2. Initially the Event Log is not initialised so new events cannot be recorded. As a workaround, erase the event log, in Comfigurator Transfer > Event Log, Clear Event Log, OR on Keypad, enter engineer Menu press 5 for event log, 0 to erase event log
  3. From firmware 7.198 - If UCM/knx, UCM/CBus, UCM/Modbus has address  mapped to Flag, Comfort broadcasts the flag to all UCMs but the source ID of the UCM changing the flag is not sent correctly by Comfort. This may cause the UCM to send an extra unneccessary message back to the external Interface for KNX, CBus, Modbus etc. This does not cause the UCM not to work , it just causes an extra message to be sent back to the Interface
Bugs Fixed
  1. Fixed bug for wifi  invalid login code reset timer
  2. Fixed bug from   7.205  action 64 to 128 error. Timer action bug stack overflow
  3. Prevent false AC Power failure and Low battery alarms caused by slow rise time of power supply by adding a sooft start delay timer.
  4. Slave fixed BUG from 16/7/16 did not load zone numbers for each zone at reset. This caused the bug that slave initial zones is always off until the zone state is changed to active
  5. fix bug SEM sometimes has problem replying to polls
  6. Fixed Bug SEM may hang at reset of EEPROM is not present
Changes and Improvements
  1.  At reset, keep S12V off for a few seconds to prevent intial high current load from external device  from causing firmware to hang
  2. u? query for Modules detected Processor 0 for toshiba, 1 for arm
  3. CM9001-EX  has max Inputs  and Outputs  > 128 (EX) by adding Slaves
  4. Slave  ID max increased from 5 to 9 so SEM ID can be 9. CM9001-EX can have 9 SEMs
  5. Increased rs485 buffer size to 600. Comfort app has many queries at start so need more buffer
  6. For phone  dialout - if by gsm dialout, ignore delay  after cms
  7. Security zone trouble sensitivity time changed from 850 ms to 2 secs to reduce zone trouble occurence
  8. Slave  does not hang at check size of EEPROM May fix bug slave caused comms fail at reset
  9. For CM9001-OPT FS31 Eventlog address is based on 256 Kbits.  event log has 600 events If EEPROM size is 64 Kbits  no of events is only 254.
  10. Fix bug at reset  Clear Flags should clear 32 bytes not 254 bytes
