Comfort with Home Assistant Live Demo
There is a demo system at http://slychiu.ddns.net:9000.
User name= comfort
password = Cytech408935
if clicking on the link shows \"this site cannot provide a secure connection\", type the IP address directly in the browser
This is on 24 hours so anyone can log on
The hardware consists of a CM9001-ULT/ARM with SEM01 slave, ETH03, a Slave and a Raspberry Pi4.  The Admin setting is disabled so no settings can be changed. The outputs are not connected to anythings so nothing can be damaged.
The Inputs 17 to 20 are Virtual Inputs; Front Door, Living Room Window, Living Room PIR, Kitchen Window.
There are switches in the UI to open and close the virtual inputs. This in turn shows the state of the Inputs separately
This allows you to Arm the system to HOME ( ie Day in Comfort) and Away. Arm to Away Mode requires the Front door to be Opened and Closed, or if it is already Open, it must be closed.
There are Lights that can be controlled by outputs: Bedroom, Living room, Dining Room (dimming). The Dining Room is a Counter so it can be dimmed by changing the value in the counter from 0 to 255.
(there are no real lights connected).
There are Comfort Responses, eg Away Arming Turns off all lights, Intruder Alarm turns on all lights, Entry Alert (Front Door opened when system is armed) turns on the Living Room Light. Also the Living Room Movement PIR turns on the Living Room Lights for 10 seconds.
Let me know your feedback or if anything is not working
TP Link camera has been added to the demo. It just points at the Comfort Metal enclosure to show that you can view cameras. This one was a bit difcult to set up because the ONVIF integration did not work for this TP-Link camera, so had to add rstp config in configuration.yaml
camera:
  - platform: ffmpeg
    input: rtsp://<username>:<password>@192.168.0.114:554/stream1
