cwm02 web page design - Printable Version
+--- Forum: Comfort Webserver Module (OBSOLETE) (https://www.comfortforums.com/forum-49.html)
+--- Thread: cwm02 web page design (/thread-1325.html)
Pages: 1 2 3
- wexfordman - 10-29-2010
Thanks again!
Also, is there any particular reason why cwm does not or can not display flag status ?
- ident - 10-29-2010
The problem with display of flags is due to the CWM firmware
The next version should fix this
Great thanks! Will the applet designer be updated also to allow the inclusion of flags?
Any approximation of when this will be released?
Thanks again
Oops Sorry about that You are correct, you obviously know more about CWMN than me. The applet does not allow the status of flags at the moment and the UCM firmware will not fix that
We will look at that change in future. As a workaround, perhaps you can use Counters instead of Flags
No bother, will look at the counters option! Prob
Means dumping the strategy of using flags on my comfigurator file and switching to counters
Another thing I noticed with cwm is that it does not display response names even whenlibkibg to the correct comfigurator file which is a serious pain! Same goes with x10 devices!!
Eamon
- ident - 11-01-2010
[user=318]wexfordman[/user] wrote:
Quote:Another thing I noticed with cwm is that it does not display response names even whenlibkibg to the correct comfigurator file which is a serious pain! Same goes with x10 devices!!
You may have missed the Check-box for \'Use Comfigurator File\' which allows you to select Responses?
Quote:Thanks again ident, you\'ve been busy :-)
Regarding the x10 devices, I understand the limitation when the device is activated manually, thanks . What I did notice is the cwm only reported
Status of x10 devices correctly when an action is initiated when logged on to webserver!
For example a timed light will behave on the following manner
Device is turned off
Log on to wevserver
Device is activated by comfort (via pir for example)
Webserver reports devices correctly as on!
However if I log off of webserver now, and then log back in again, comfort reports the device as off, even though it has not been turned off!!
Eamon
You are correct that X10 devices wil show their correct status only when the CWM is logged in when the X10 commands are sent and when the CWM logs in, the X10 status is off  It does not have a memory for X10 status. This is to be investigfated for the future. However X10 is become less popular as other technologies and products appear
- wexfordman - 11-01-2010
Thanks ident,
It does make the cwm a bit Redundant if that us the case :-(. Is a fix planned or difficult to implement ?
X10 is generallly difficult to monitor and the usage is going down
I suggest a workaround of using X10 Responses to load Counters so you can use Counters to monitor the X10 status
God idea, will give it a go! My entire house was wired 10 years ago with din rail x10 modules! Nit easy or cheap to replace with the z wave eib or cbus!
Eamon
