No voice output at Door Station - Printable Version
+--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html)
+---- Forum: Door Station Problems (https://www.comfortforums.com/forum-130.html)
+---- Thread: No voice output at Door Station (/thread-1658.html)
Pages: 1 2
- jbarne41 - 11-05-2009
Thanks Chiu,
Yes nice idea, a new DS01 might solve the problem, but at £450 iam afraid i\'ll have to live with replacing the £2.95 speaker every couple of years. ( Not sure I will live another 300 years to recoup the cost saving Big Grin)  Will look at your suggestion of the speaker touching the metal faceplate as a possible cause of failure.
Pedro..
I presumed replacing the original paper coned speaker with a mylar one would solve the problem... clearly not. As Chiu states the speaker should be a 32ohm 1 watt. Just need the Diameter... do you have yours to hand to measure? I will take mine apart as soon as I get home..but won\'t be back till the weekend and was hoping to order a replacement so I only had to take it apart once.  Just had a look on the net and having trouble finding 32ohm 1 watt speakers of any size and cannot remember where I sourced the last one.. Anybody got suggestions?
Joules
- Podro - 11-05-2009
In my DP03 it is a 32 OHM 0.5 W 40mm, in my DP02 it is a 65mm 8 OHM 3 W showing part no. FE202M8NG.
Hope that helps, in the meantime I am going to see if I can make one good doorphone out of three bad ones Wink
Paul
Will this work?
http://cpc.farnell.com/_/59-f67-00-01f/square-speaker-8ohm-3w-66cmm/dp/LS00461
- slychiu - 11-05-2009
That is an 8 ohms speaker which is not trecommended. Look for a 32 ohms speaker
But that is what is in the DP02.  As you say Comfort UK made these panels so presumably fitted a different speaker.
As I said we dont know what they put in there. It is not the correct rating for the door station.
- Podro - 11-10-2009
Just for information I contacted Comfort Home Controls and they sent a replacement speaker in the post to me. What arrived was this unit:
http://cpc.farnell.com/mylar/so66m/weatherproof-speaker-66mm/dp/SR00187?Ntt=sr00187
In case anyone needs if for future reference they are available in stock from CPC.
Thanks!
- jbarne41 - 11-11-2009
Thanks Podro,
Will order a couple, didn\'t think they were 66mm. Presumably the reason they fail after 18 months is that they are only 8ohms as opposed to 32ohms. But seeing as I cannot seem to source a suitable 32ohm speaker and cannot afford a new door station, I will have to live with replacing them every 18 months or so.
Joules
