Sensors and flags not reading - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: WizComfort (https://www.comfortforums.com/forum-21.html) +--- Thread: Sensors and flags not reading (/thread-2011.html) Pages:
1
- wexfordman - 10-28-2010 Hi ident, I was thinking same, but could not find any info on cwm fw upgrades etc! Not sure at the moment what fw version it is! Is it possible to check this remotely? I do know I went in to cwm admin and tried to update, and it said all was up to date! Regards Eamon - wexfordman - 10-28-2010 Okay here is where I understand I am at the moment. CWM firmware needs upgrading or at least the ucm within the cwm ? I tried to follow the normal ucm upgrade process, and got the error message \"product number or type does not match\" I was using the \"ucm5_212.cbf\" firmware version, I can see no specific firmware for cwm ? Adivce would be greatly appreciated. - ident - 10-29-2010 The CWM firmware is a different type from the UCM so you cannot use a UCM cbf filel to upgrade the CWM. The current CWM firmware is 5.128. We will shortly release an upgrade that will allow you to see the flags etc and can be scanned by Comfigurator - wexfordman - 10-29-2010 Thanks ident, Regards Eamon |
