UCM/Universal 6.010 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Restricted (https://www.comfortforums.com/forum-8.html) +--- Forum: Special Problems (https://www.comfortforums.com/forum-99.html) +--- Thread: UCM/Universal 6.010 (/thread-2449.html) Pages:
1
- ident - 09-07-2011 The new Comfigurator 3.3.2 which does not have the execptpion problem should be out next week Lets see if that was the problem - ident - 09-14-2011 [user=271]palmlodge[/user] wrote: Quote:I cannot upgrade over the BUS to 6.010 - Comfort is at 6.005, U-UCM is at 6.003 - it says \"Bus firmware upgrade not supported\" Note : this is still using Comfigurator 3310 which has the scanning bug that causes an exception on every odd iteration of scanning modules (whether for an upgrade or the usual UCM module scanner) What am I doing wrong ? The Universal 6.003 may have some problem upgrading by Bus.Can you do a upgrade using the old way to 6.010. This firmware should allow firmware upgrade by bus |
