Output Current Limitation 300 mA - Printable Version
+---- Forum: Outputs (https://www.comfortforums.com/forum-71.html)
+---- Thread: Output Current Limitation 300 mA (/thread-2481.html)
Pages: 1 2
- John W - 05-13-2018
You might find that while the cable doesn\'t look damaged,it\'s insulation is breaking down.
Disconnect it and stick a meter across it to check the core to core resistance. If you have a megger insulation tester disconnect all devices and try with that.
