Latest UCM/USB with old Comfort I Ultra - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Comfort I Issues (https://www.comfortforums.com/forum-101.html) +---- Thread: Latest UCM/USB with old Comfort I Ultra (/thread-2531.html) Pages:
1
- Howser - 11-21-2011 Got the file and tested the convert. No errors. Will make some time and load it. Is it safe to load the edited Comfort I project into the old Panel? - ident - 11-22-2011 I am not sure which you refer as the old panel, do you have a new and old panel? Comfigurator 3.3.3 will prevent you from writing the wrong file system into a Comfort - Howser - 11-22-2011 [user=86]ident[/user] wrote: Quote:I am not sure which you refer as the old panel, do you have a new and old panel? File System 24 into Comfort I (the old panel). - ident - 11-22-2011 You can write the file to Comfort 1 Pro if it is File system 24 and have not converted to File System 34 (for Comfort II Ultra) - Howser - 11-30-2011 I managed to load the converted project into the Comfort II panel. All looks good. The only thing I noticed (in the event logs) was two events (one after the other) are announced for each user signin, am I doing something wrong? - ident - 11-30-2011 No events sometimes seem repeated, but it is normal |
