Zone and Zwave Feedback - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Zone and Zwave Feedback (/thread-2595.html) |
- lwillerton - 11-15-2011 Hi Ident I have not had much luck with this. Using the keypad I just get light on even if their off and the iPhone app shows all off even if they are on. I have run the CCLX file through the email conversation program so should be the same as on the hardware. Oh and the icon on the garage door status seems to have changed Cheers Lee - ident - 11-16-2011 Did you Write to EEPROM for the UCM/Zwave? If so and it does not work send the file to support@cytech.biz - lwillerton - 11-16-2011 Hi Ident, No had not written to eprom and did not realise I had to so working now. Cheers Lee - lwillerton - 11-19-2011 Hi Ident, Last one on this I hope. Why does the garage door show as a percentage? I can\'t upload a pic right now but the response it set to a on / off reed switch. Cheers Lee - ident - 11-20-2011 A percentage is shown if your assigned counter has a value between 1 to 254 Check what the zwave status is - lwillerton - 11-20-2011 Hi Ident, I had set this as a sensor as the trigger is a reed switch. So assumed it was open or closed. Cheers Lee - ident - 11-21-2011 Can you send your cclx file so we can check, to support@cytech.biz - lwillerton - 11-21-2011 Hi, Just realised what the problem is.... The unit showing a % is not the garage door sensor as I though, but an old z-wave light moduel I had replaced. :-( sorry to waste your time. guess i need to go round the z-wave network and delete the missing item. Lee - lwillerton - 11-21-2011 Hi All, Figured out what I had been doing wrong and all good on the lights now.... I had just setup the control bit wrong :-( Ident / Chiu thanks for your patients. I agree that the zone state is shown so I can see status of the garage door there (this is working). However, I would if possible like to see it in the control menu. - lwillerton - 11-21-2011 Continues |
