Upgrade of SPC Firmware - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Firmware Upgrading Problems (https://www.comfortforums.com/forum-111.html) +---- Thread: Upgrade of SPC Firmware (/thread-2715.html) |
- ident - 02-01-2012 The problem is that your system is SPC firmware but you are trying to upgrade to ULT This is not allowed hence the message Product Type Does not Match Firmware camn only be upgraded to the same type Try upgrading to SPC 6.011 attached Your UCM will also need to be upgraded to the latest - ident - 02-01-2012 I have renamed this topic Upgrade of SPC Firmware instead of Upgrade to the Vocabulary - nbexiga - 02-01-2012 Ok, later when i arrive home i\'ll try this firmware that you post. regarding the UCM upgrade , are you refering to the Ethernet UCM right? if yes for wich firmware should i have to upgrade to? and i will be able to upgrade the Ehernet UCM firmware with the boards that i have? or do i have to have a USB board to upgrade the Ethernet board? Many thanks for your help so far! hope i will have Iphone working ![]() ![]() - nbexiga - 02-01-2012 [user=86]ident[/user] wrote: Quote:I have renamed this topic Upgrade of SPC Firmware instead of Upgrade to the Vocabulary Ok, thanks. It make more sense ![]() - ident - 02-01-2012 Your UCM firmware is alreadu 6.002 so that should work with iPhone app see http://www.comfortforums.com/forum96/2327.html I would try it before uograding the UCM firmware UCM 6.002 firmware canbe upgraded by direct connection to PC without needing another UCM and not needing a programming cable see http://www.comfortforums.com/forum4/2283.html - nbexiga - 02-01-2012 haaa ![]() ![]() ok , after i upgraded the central i\'ll try to do it in the Ethernet. like this way you mencioned i\'ll updated you when i back home. ;9 thanks - nbexiga - 02-01-2012 Hi , ![]() ![]() ![]() ![]() VERY GOOD NEWS ![]() The central is already updated! NONE ERRORS ![]() ![]() Iphone is now working with the central! EHEHEHEHEI\'ll try to do the upgrade of the Ethernet UCM now!! heehehMANYYYYY MANY THANKS!!!
- nbexiga - 02-01-2012 Hi have the ETH01 ... ive tried to upgrade the firmware to 6.008 but it gives me that this version is not for that module.... for which firmware should i have to upgrade? - nbexiga - 02-01-2012 OK ![]() ![]() DONE BOTH!! ![]() NOW EVERYTHING IT\'s oki!!!! ![]() MAny thanks for the HELP!! Really appreciated! Have a very nice day! - rportela - 02-01-2012 Hello, I have exactly the same versions, but I have a LEM board on top of the Confort. Can I just unplug this board (including flat cable) to do the connections, and the upgrade ? |
