SUC/SIS role in a network - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: SUC/SIS role in a network (/thread-2901.html) Pages:
1
- ident - 06-13-2012 The UCM/Zwave manual has been amended to 2.09 which clarifies the repatetd use of Learn mode is the same as replication - gaynorc - 06-13-2012 I am not entirley sure that answers the question. The two \"basic nodes\" appeared immediately after the creation process and before I reset the UCM device. Okay, sometime in the next couple of days I will try to create a single virtual node using these updates instructions, record each step of the way, and report back. Thanks again for all your help. - gaynorc - 06-14-2012 This evening I followed the instructions on creating a virtual node using the advice you gave me. The node was successfully created. Associations to the node were created and a response to it was added and saved to eeprom. It worked. A new association was added, and the response modified. I attempted to save once again to eeprom. Error: ââ¬ÅInvalid data in EEPROM. Please Learn Againââ¬Â Using learn and \"inc\" the network was learned again. BUT: The node reverted from \"virtual\" to \"basic\", AND NOW CANNOT BE USED. If you can PM me an e-mail address I will send word document with screen prints and more detail. - ident - 06-15-2012 Please send all info inclduing the cclx file to support@cytech.biz - gaynorc - 06-15-2012 Files sent |
