Communication KNX-Cytech problem - Printable Version
+--- Forum: KNX (EIB) (https://www.comfortforums.com/forum-12.html)
+---- Forum: KNX Support (https://www.comfortforums.com/forum-112.html)
+---- Thread: Communication KNX-Cytech problem (/thread-2939.html)
Pages: 1 2
- mario.jr - 09-28-2012
Most of my KNX telegrams to COMFORT are for value 1 (in counter FF (255)). Is for this that after the second press does not the response. Two weeks ago they did not, but I\'m not sure since when it does. Maybe for a firm change.
The only solution I have given is to the response to reset the counter to 0.
Thanks.
- ident - 09-29-2012
Why not change the KNX button to send 1 and 0 alternately?
If you cannot do that then in the Counter response, set the counter to 0. Then the next button press will see the counter change to FF again
- mario.jr - 09-29-2012
That is another alternative. But for me it is more easy to modify the COMFORT, not the KNX.
What most surprises me is that with the same programming comfort of a month ago I was successful, but not now.
Thanks for all.
- ident - 09-30-2012
[user=4315]mario.jr[/user] wrote:
Quote:That is another alternative. But for me it is more easy to modify the COMFORT, not the KNX.
Thanks for all.
I am sure Comfort will act the same way, if you examine the old and new programs
This topic will be closed as there are too many different matters posted in the same topic Please start and new topic if there are any other problems
