Error of the words on the keypad KP04 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Keypad (https://www.comfortforums.com/forum-69.html) +---- Thread: Error of the words on the keypad KP04 (/thread-3017.html) Pages:
1
- ident - 08-24-2012 We have done a vocabulary upgrade for the marta.bin file The words announced is the same as the LCD Display. There is nothing wrong with the bin vocan file However If I select Portuguese Residential in my Comfigurator, the words are not the same as the words announced or displayed on the LCD Is this the problem that you mean? This is because the Marta.bin file uses differebt word numbers than the Portuguese residential configuration that is in Comfigurator In Comfigurator > Config folder there is a file called vocab.cfg which has the contents below >WordList 00=Standard Residential,cs-wl-std.cfg,sentence.cfg 01=Chinese Residential,cs-wl-ch.cfg,sentence-ch.cfg 02=UK Residential,cs-wl-uk.cfg,sentence.cfg 03=Italian Residential,Italres.cfg,sentence-it.cfg 04=Pagewatch,cs-wl-pw.cfg,sentence.cfg 05=English Residential,newengwl.cfg,sentence.cfg 06=Australian Residential,cs-wl-au.cfg,sentence.cfg 07=Thai Residential,thai.cfg,sentence.cfg 08=Spanish Residential,spanish.cfg,sentence_spa.cfg 09=English Industrial,indus.cfg,sentence.cfg 10=Chinese Residential,chinese.cfg,sentence-ch.cfg 11=Portuguese Residential,portuguese.cfg,sentence-port.cfg 12=Thai Residential C1,cs-wl-th.cfg,sentence.cfg The entry for Portuguese Residential uses portuguese.cfg These are text files which determine which words correspond to the word numbers You can open the cfg files using a text editor The Marta.bin file must have been done by someone who made a different portuguese.cfg file or has a different filename for portuguese in vocab.bin It may have worked before because you had the correct cfg files in Comfigurator But when you upgraded to a new Comfigurator, the old files were overriden Can you get the previous vocab.cfg file and the portuguese.cfg fiies that you used before? - Canha - 08-24-2012 Hi ident Probably it could be the reason why its wrong. When the keypad started the with the wrong announcements i\'ve downloaded only the .bin file and not the other two .cfg files. I will download the other two files, and try again and I will let you know soon as possible. Thanks for you attention. - ident - 08-24-2012 Thanks, can you send the 2 cfg files so that we can help others with the same problem in future - Canha - 08-24-2012 Hi ident Still not working. I\'ll send the files that I used for this project. Thanks - slychiu - 08-25-2012 Your problem is that the person who provided the marta32.bin file modified the vocab.cfg and provided the cs-wl-pt.cfg file which is the wordlist In the modified vocab.cfg Portuguese Residential points to cs-wl-pt.cfg When you installed a new Comfigurator, the default vocab.cfg wil override the modified vocab,cfg hence Portuguese Residential would point to portuguese.cfg which is not the same wordlist as marta32 I have attached a new vocab.cfg file which adds a new entry Portuguese Marta which points to cs-wl-pt.cfg Save this to Comfigurator > config folder When you open your cclx file, select Portuguese Marta instead of Portuguese Residential in Modules and Settings > Wordlist This will select the correct wordlist Save a copy of the vocab.cfg file under a diferent name so when you upgrade comfigurator, you can rename it back to vocab.cfg - Canha - 08-27-2012 Hi slychiu I\'ve alredy edited the file and it\'s working fine now. I didn\'t noticed this change before. Thanks very mutch for your attention. Avelino Canha |
