6.028 upgrade - Lost vocabulary - Printable Version
+---- Thread: 6.028 upgrade - Lost vocabulary (/thread-3088.html)
Pages: 1 2
- ident - 10-15-2012
yes, according to point 3
- lwillerton - 10-15-2012
ok done that and nothing,
so just to confirm I pressed f and released followed by 0, and then clicked ok in comfigurator. mesage jumps back saying press f0.
repeated a few times, same result.
Does the log help?
off to work now, so will try  any other suggestions later
> LI****
< LU02
> UL000003
< DL00000305FF22D7
> V?
< V?FE060B22200100
> v?
< v?05FF23010203FFFF
> U?
< U?0A060811
> u?11
< u?110A0608
> u?12
< u?120E0613
> u?13
< u?13FFFFFF
> u?14
< u?14FFFFFF
> u?15
< u?15FFFFFF
> u?16
< u?16FFFFFF
> u?17
< u?17FFFFFF
> u?18
< u?18FFFFFF
> u?11
< u?110A0608
> u?12
< u?120E0613
> u?13
< u?13FFFFFF
> u?14
< u?14FFFFFF
> u?15
< u?15FFFFFF
> u?16
< u?16FFFFFF
> u?17
< u?17FFFFFF
> u?18
< u?18FFFFFF
> u?41
< u?41040111
> u?42
< u?42FFFFFF
> u?43
< u?43FFFFFF
> u?44
< u?44FFFFFF
> u?45
< u?45FFFFFF
> u?46
< u?46FFFFFF
> u?47
< u?47FFFFFF
> u?48
< u?48FFFFFF
> u?31
< u?31030104
> u?32
< u?32FFFFFF
> u?33
< u?33FFFFFF
> u?21
< u?21FFFFFF
> u?22
< u?22FFFFFF
> u?23
< u?23FFFFFF
> u?24
< u?24FFFFFF
> u?25
< u?25FFFFFF
> u?51
< u?51FFFFFF
> u?52
< u?52FFFFFF
> u?53
< u?53FFFFFF
> u?54
< u?54FFFFFF
> u?55
< u?55FFFFFF
> u?56
< u?56FFFFFF
> u?57
< u?57FFFFFF
> u?58
< u?58FFFFFF
> u?59
< u?59FFFFFF
> u?5A
< u?5AFFFFFF
> u?5B
< u?5BFFFFFF
> u?5C
< u?5CFFFFFF
> u?5D
< u?5DFFFFFF
> u?5E
< u?5EFFFFFF
> u?5F
< u?5FFFFFFF
> UL000003
< DL00000305FF22D7
> V?
< V?FE060B22200100
> v?
> U?
< U?0A060811
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
> UB05010E061812
< UBF5
Can you send your cclx file to support@cytech.biz thanks
You have deleted the Response Engineer Code which should be assigned to the F0 key in Control > Keypad
Hence F0 is not having any effect
The screenshot is what it should be like
Can you add the Response as shown
If in doubt open a default Template and copy the Response exactly
