eth02 firmware might not be compatible - Printable Version
+---- Thread: eth02 firmware might not be compatible (/thread-3114.html)
Pages: 1 2 3
- juwi_uk - 12-30-2012
What does Device Explorer show?
- raygregg114 - 12-30-2012
also since the upgrade was done I cannot arm the system in either night or away mode. I did an upgrade to my GSM module and the Ultra 2 module yesterday. sine then nothing seems to be working.
was showing nothing and giving a message that auto discovery couldn\'t find anything. Initalised again and now showing blue barrel with IP address.
Sounds like you are making progress then. So you can now also see in DS Manager and connect OK?
Yes, can click ion blue barrel and go into settings. Says IP address is 192.168.1.20, gateway is 1.0.0.1, DHCP is disabled and submask is 0.0.0.0
Your Gateway and Subnet address do not look right to me.
I would have thought you would have
GW Address: 192.168.1.1
Subnet mask: 255.255.255.0
DS manager now cannot connect when I refresh, says no devices were discovered but I am running a constant ping and the IP is there.
Ran device explorer and rebooted. Went to DS Manager and refreshed, device was listed. Now when I refresh it says Reading SDF from device, no response.
Not sure if this will help, but below are the settings for my ETh02. Perhaps generally compare and see if you have anything different (name/IP etc excepted). Wondering if perhaps baud rate is different etc on yours.
- ident - 12-31-2012
Reading SDF from device is shown briefly when you double click the device or select settings for it
If you still have problems attach a screenshot of DS Manager settings
