Fibaro Relays - Printable Version
+--- Thread: Fibaro Relays (/thread-3125.html)
Pages: 1 2 3 4 5 6 7 8
- lwillerton - 06-20-2013
Hi Hendy,
Please see HomeSeers imange
I have changed the name of the 2 switchs connected to fibaro 39 one is fire light the other is lounge LED, fibaro 44 I did not rename.
- juwi_uk - 06-20-2013
Here are my Fibraro 2x1.5 switches (highlighted in yellow) after learn to comfort.
I think the on/off test in Comfigurator only turns on/off Channel 1.
You can turn off other channel via response though as per normal operations.
J
- hendy - 06-21-2013
Hi Lee,
are you turning on/off the switch through Comfigurator\'s Switch Device On/Off buttons?
If yes, then what Julian said is correct that the Zwave\'s on/off buttons in Comfigurator are for test purpose (to identify a node) and will only turn on/off first channel of a module.
- lwillerton - 06-21-2013
Hi Hendy,
Yes I am turning on / off in the modules tab - ucm2 - z-wave mapping - on / off.
Do I need to control switch 2 on fibaro vai programming then?
Lee
Thank you so much Juwi / Hendy.
I will try to program later.
Best Regards
Lee
- lwillerton - 09-12-2013
Can I ask which primary controller you used? I have an aeon labs z-stick 2 and I only get a basic node.
If I use UCM fiware 6.23 I can control both switches but if I upgrade to the latest UCM firmware (7.xx) I am unable to control both Fibaro switches switch one is ok but switch 2 just doesn\'t work.
I am running my z-wave UCM at 6.23, but I am getting random on\'s from z-wave modules. I have looked at my code and can\'t seem much wrong so suspect its a z-wave network thing.
Any thoughts... Especially around the primary controller as I have just purchased 3 danfoss z-wave trv and want comfort to manage the temperature points
Best Regards
Lee
- juwi_uk - 09-12-2013
I use the remotec ZRC-100 that Vesternet sell in the UK.
Great, I have just ordered one from vesternet £75.
Have you got any danfoss z-wave thermostates?
Cheers
Lee
Nope. Boring old TRV\'s for me at the moment.
Next project is to rip out my old Smartfit boiler control (as my UCM/Smartfit is from the dark ages) and replace with the Heatmiser setup and new UCM/HM-Eth.
I just use ZWave for lights at the moment.
