Doorbell Response Not Working - Printable Version
+--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html)
+---- Forum: Door Station Problems (https://www.comfortforums.com/forum-130.html)
+---- Thread: Doorbell Response Not Working (/thread-3210.html)
Pages: 1 2
- waynebr - 12-27-2012
Hi I am still having issues with this, when in away mode it dials to my mobile but I cannot limit the numbers, all the rest of my responses appear to work but not the call divert. I have put flags in to say if they are empty then dial to none but it seems to ignore these, I also have flags to say if user 1 is checked dial user 1 and if user 2 then dial user 2. When the system has rung me I just hear wrong code. Are you able to help? I guess I must be doing something wrong but not sure what
- ident - 12-29-2012
We have checked your cclx file and have sent an email to explain in detail
For the benefit of the forum, the issues are
Doorbell Response runs whenever the doorbell is pressed
Doorbell Alarm Response runs only in Away Mode. Hence there is no need to check for away mode or night more in this response
You have the same Response allocated to Doorbell Response and Doorbell Alarm Response. Hence the same response will run 2 times in Away Mode, as Doorbell Response and as Doorbell Alarm Response. You have flags which change state in the response, hence when the Response is run again the flag is changed back to the original state ie off
The Limit Dialout action must be placed in the Alarm Response in order to work
In Comfigurator 3.6.2 You can check the status of the flags in Names > Flags by checking the Show status box. This tells you what the flags are doing, which helps you to troubleshoot the program
- waynebr - 12-29-2012
Thanks I\'m in the process of changing the response and testing. I have rolled back my firmware
- waynebr - 01-06-2013
Hi I am still having issues with this, I have broken down the responses so they cannot run at the same time, however in away mode it will only dial to the default number, in day mode is does not dial out, however when I disarm the security after applying the response it dials my mobile and I hear security off. I will send you my file again thanks
