Keypad scan adds invalid keypads - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +--- Thread: Keypad scan adds invalid keypads (/thread-3368.html) |
- mikegriff - 05-02-2013 I have had this! 7.026 and 7.026 or could be the new configurator 3.6.6 to 3.6.8 the only cure I had was to delete all the keypads and re scan this cured it Till the next time Mike - juwi_uk - 05-02-2013 If you exit configurator and go back in again and login and scan does it find the phantom ones again. It does in my setup. If not you say deleting all and scan fixes. I must admit I only deleted the KP04 one in my config and left in the KP06 definition so didn\'t test this scenario. If deleting them all works this would suggest some missing keys un the CCLX file for the older records. Julian - mikegriff - 05-02-2013 Hi Julian Sorry I might have confused things I do a scan I then end up with my 4 Keypad KP04 and 4 Ghost Red Keypads I cant just delete the extra ones as the id are then screwed so I have to delete them all I scan again I end up with the right number I\'m then safe to upload a set up to Comfort If I want to do it again I have to delete everything scan and upload Safely Mike - juwi_uk - 05-02-2013 Hmm, same as me. Chaps at Cytech; have you managed to recreate this yet as you seem a bit quiet in responding on this one? Julian - hendy - 05-03-2013 I\'m running Comfigurator 3.6.8, Comfort ULT 7.027 and UCM 7.016 (all latest release versions for now).
I did however get a red (not found) keypad if I do the following:
- Ingo - 05-03-2013 This is my scenario. I\'m running Comfigurator 3.6.8, Comfort ULT 7.027 and UCM 7.019(Beta). 1. Run Comfigurator and Edit the default Connection method to use Network (Local) and add IP of UCM. 2. The two keypads (KT03 and KP04) connected on my test bench. 3. Scan for All Modules, enter LoginID and Scan produces phantom Keypad010. 5. Close Comfigurator and go back to #1 produces the same result over and over. Ingo - hendy - 05-03-2013 Ingo, how about if you delete the phantom keypad, save the config, exit the Comfigurator and then re-open the saved file to do Scan for Keypads; will this still produce a phantom keypad? - Ingo - 05-03-2013 It\'s not about a saved config at all. I start Comfigurator with a default blank config, change the connection setting to use IP and then do a scan and voila, phantom keypads. By loading an existing config, doing a scan, deleting the phantom keypads is just fixing the symptoms and not the cause. Ingo - juwi_uk - 05-03-2013 It\'s worry in that you guys cant recreate this. What else could be different in our setups. We are all so able to reproduce that it hurts!! :0) Hendy are you testing eth or ucm connected ucm. Im on eth2 if this message makes any difference. J - hendy - 05-03-2013 Julian, I have tried with both the UCM/ETH02 and UCM/USB and able to reproduce the phantom keypad issue to a certain extent as indicated in my previous post. And I\'m aware that the countermeasure offered is not a fix for the cause but merely a work-around for the time being (as Ingo has suggested); while at the same time I raised this issue to our software guys. |
