Reliability problem - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Reliability problem (/thread-3505.html) Pages:
1
- emabonacchi - 09-05-2013 The result, now is I?1801 So, it is ok....... Well, at this point, i don\'t understand where the problem can be..... - ident - 09-05-2013 Comfort never reports zones or alarms wrong It should be the homeseer plug in not sending the corect commands or not interpret the results correctly If there is a monitor mode for Homeseer which can show the messages excahnged between Homeseer and Comfort, use that to check - emabonacchi - 09-05-2013 Going on making some tests, i have a reply asking \"I?2\" >I?2 <Ok <NA Many other inputs reply \"NA\", what does it means? - ident - 09-05-2013 You need 2 digits 02 not 2 - ident - 09-05-2013 An easier way is to go to zone screen, select the zone and check the status box This will show you the state - emabonacchi - 09-05-2013 Comfort monitor gives the right results. You was in right when you said \"Comfort never reports zones or alarms wrong\"..... The problem is not a Comfort problem...... well, now i don\'t know what to do....... - ident - 09-06-2013 Check with the author of the plug in? - juwi_uk - 09-06-2013 Use ComfortClient?
- slychiu - 09-07-2013 [user=876]juwi_uk[/user] wrote: Quote:Use ComfortClient? yes, and has much better support - juwi_uk - 09-07-2013 Awe you\'re making me blush now.
