Comfort playing up - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Comfort playing up (/thread-3556.html) |
- HomeIQ - 11-07-2014 Hi dcera, The OP1 is a driver for outputs like relays and could be damaged from voltage spikes from switching, or lightning strikes which I see often in South Africa. I can supply a replacement OP1 to test if this resolves the problem, please contact me (brad at homeiq dot co dot za) thanks Brad - dcrera - 11-07-2014 Thanks Will chat on later - dcrera - 11-13-2014 Hi I have changed the OP01 from the Lem to the motherboard as per instructions and downloaded from PC. Outputs still do not work. Ordered new ones and repeated the process and still does not work.:X Please assist Regards - slychiu - 11-19-2014 If a new OP01 does not work, there must be a fault on the CM9000 Let us have the serial number of the CM9000, it shoyld be in a label starting with P... - dcrera - 11-19-2014 Hi I could not find a label starting with P.. I did find a number in black just above the output row 850617 Also found a white label with A018225 Hope this helps - slychiu - 11-20-2014 That serial number indicates that the PCB is from 2006, is that correct? It appears that there is a fault in the main controller PCB driving the outputs. It needs to be repaired or replaced. Instead of repair, you may want to opt for an upgrade of the PCB at a much discounted price. Send a PM or email if you would like that option - dcrera - 11-27-2014 Hi I upgraded my system to the new CM9000 motherboard. I also updated to the new Comfigurator 3950 Problem is none of the inputs on the LEM are responding I doubled checked that the ribbon cable is connected to both the Lem and motherboard. Any advice on how to rectify Thanks - CytechMartin - 11-28-2014 How do you check that your LEM inputs are not working? Can you send me your cclx file to support@cytech.biz - dcrera - 11-29-2014 Hi Apart from the problems listed above, I have other issues None of the outputs activate on any of the programmed responses. I did a test on each and found that output 8 is activated ON, I can\'t turn it off. I did a grid graph and it shows it is activated on an Irx15 response I don\'t have any scene switches I have attached the ccl file for your comment Regards - dcrera - 11-29-2014 Hi After much trouble shooting the problems with my outputs was related to a faulty LEM. Removing the LEM has got the outputs to work. Turns out I did not need a upgrade, just the LEM. However that has its own issues. I can\'t arm the system because of zones troubles. If I try to force arm the system by pressing #, I comes up with ARM FAILURE Z Any ideas on to bypass all zones on the LEM Regards |
