Firmware upgrade for Comfort II SPC? - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html) +---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html) +---- Thread: Firmware upgrade for Comfort II SPC? (/thread-3560.html) Pages:
1
- nbexiga - 10-16-2013 Hi Just to update you with the status of the issue that i am having: I\'ve just tested one thing and i rollback for the older version of Comfort firmware 6.011, i let the UCM in the current version (7.028) and the responses and outputs are working fine now. The application errors that appear are still appearing Does my comfort don\'t allow to be upgraded to the new firmware version? Or if is possible how can i do that? Thanks - slychiu - 11-02-2013 This is to update that the cause of the exception was found to be due to an invalid serial number generated after upgrading to the new firmware 7.040 This issue will be fixed in the next firmware and also Comfigurator will not generate the exception - nbexiga - 11-04-2013 one more time tahnks for your help on this . you were very promptness and always with a solution. Many thanks! |
