ULT 7.047 to / 7.050 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html) +---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html) +---- Thread: ULT 7.047 to / 7.050 (/thread-3675.html) Pages:
1
- srooks - 04-22-2014
Thx, - ident - 04-22-2014 A KT03 slider is mapped to a Counter so you can program as follows, assuming counter 2 Get Counter Counter002 Do Response XXX After 0 Seconds Using Timer01 This will take the value from counter 2 which came from the slider and use it as the delay before the Response XXX - srooks - 04-22-2014 What about scaling. What\'s the best way of converting a slider with a range of 1-10 into seconds (60 - 600)? A KT03 slider can only have values of 0 to 255. Thanks! - ident - 04-23-2014 You can use the Multiply action eg Get Counter Counter002 Multiply Immediate 60 Set Counter002 Do Responsex After 0 Seconds Using Timer01 counters have range of up to 65535 |
