Tamper false alarms - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Tamper false alarms (/thread-3779.html) Pages:
1
- ident - 04-20-2014 Quote:Thanks if it was the same circuit I would say that it is faulty wiring however everytime it happens it is a different circuit, I did once check the wiring on a circuit after the tamper alarm and found no fault. It must be something else as i\'m using EOL is it possible that comfort is maybe reading it wrongly occasionally? if not then I don\'t know what it is. I read the log and it said it was a tamper There is only one Tamper input What do you mean it happens on a different circuit? What is the tamper connected to? Are there any possibility of interference on the wiring. Comfort cannot \"read\" the input wrong sometimes. EOL does not prevent false alarms. The input has to be open to cause a tamper alarm. Check the voltage on the tamper input. As I said, just short the tamper input and see if you have any more alarms. That will prove if it is due to comfort or not - Vangelis - 04-22-2014 The OP is using EOLs, therefore the Tamper will be read as a change in resistance on the Zone Input as opposed to using the dedicated Tamper input (which as you state is N/C). Tamper\'s would therefore be registered on each circuit, and as the triggering circuits vary, then it would indicate an issue with either a simultaneous breakdown of the all EOL resistors or the way Comfort is interpreting the input. Guess a check would be remove the EOLs (depending on location) and see if that Zone re-triggers a \'Tamper\' Vangelis - ident - 04-22-2014 Quote:The OP is using EOLs,You mean the Inputs use EOLs How many inputs are being used as Tampers? Each zone type has a zone sensitivity which can be set to a high value if there are fast transitions that are causing the alarm. - Vangelis - 04-22-2014 [user=86]ident[/user] wrote: Quote:OP = Original Poster, but I can see where the confusion comes fromQuote:The OP is using EOLs,You mean the Inputs use EOLs ![]() Vangelis - waynebr - 04-22-2014 Hi and thanks for the replies, I am using double eol\'s for each zone, each zone has 1 sensor or 1 input. Every zone will have its own eol on it. For the tamper circuit itself it\'s only the case and sirens connected - ident - 05-03-2014 ULT 7.056 (beta) has an addtional filtering for tamper alarms which may be caused by spurious external induced voltages along the wires You can try that and see if it reduces the tamper alarms http://www.comfortforums.com/forum79/3778.html - waynebr - 05-03-2014 Thanks, I will take a look at it. - dipo_19 - 05-26-2014 my comfort security keypad lights are not on only the home led light is blinking.what could be the cause and what can i do to rectify the problem - ident - 05-26-2014 This has already been answered here http://www.comfortforums.com/forum69/3056.html You do not need to post the same thing on more than 1 forum. Our support will answer the problems regardless of where it is posted And it is best to start a new topic unless your problem is exactly the same as the one originally posted |
