Zwave and Cbus/other Lighting Platforms - Printable Version
+--- Thread: Zwave and Cbus/other Lighting Platforms (/thread-3916.html)
Pages: 1 2 3
- juwi_uk - 08-10-2014
The Object Matrix in my latest ComfortClient version may be of help here as you can monitor the situation over a period and then just output the history for the selected counters.
I have noticed a similar \"counter flicker\" with one of my ZWave responses when testing the Object Matrix.  I have a door sensor and PIR that, at night, the light is meant to turn on when somebody enters from outside.  The response works fine but I think it creates a lot of counter updates for some reason which I\'ve yet to debug myself.
Anyway just a thought.
- Howser - 08-11-2014
There are no responses or any other references to this counter except Zwave.
- ident - 08-27-2014
Hi Howser
Is this issue resolved? Does it happen again?
- Howser - 08-29-2014
I have been logging activity on Zwave side (with NO CBUS mapping) and I could not reproduce the issue.
I will re-map CBUS and see if that makes any difference.
- Howser - 09-05-2014
It is still occurring. When it does, the GA is turned ON and then OFF a couple of times (from CBUS it looks like Comfort is doing it). Most of the time, ON is immediately followed by OFF.
Code:
2014/09/05 03:16:07 AM    Lighting             Group= 100  Unit= 127                       Event= Group on
2014/09/05 03:16:07 AM    Lighting             Group= 100  Unit= 127                       Event= Group off
2014/09/05 03:16:22 AM    Lighting             Group= 100  Unit= 127                       Event= Group on
2014/09/05 03:16:23 AM    Lighting             Group= 100  Unit= 127                       Event= Group off
- ident - 09-06-2014
To determine the cause of this, we need the Bus Monitor
This will show what causes the counters (or flags ) to switch on or off
- Howser - 09-10-2014
I have emailed the logs to support.
- ident - 09-13-2014
The Bus monitor log shows the the UCM/Zwave  (UCM ID 4)  is triggering the Counters 100 and 253 from a multichannel device. The counters 100  is mapped to your cbus Family Room side lamp, while 253 is not mapped to any Cbus group
You wil have to investigate why the zwave channels are triggered  from the Zwave device
- Howser - 09-17-2014
I will investigate Zwave side.
- Howser - 10-01-2014
I investigated the Zwave side and looking at the logs (attached), I can see the node being polled, but nothing purely switching the node ON and OFF.
08    09/30/14 22:47:41.504    JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-comConfusederviceId:HomeAutomationGateway1 <0x2d9db680>
08    09/30/14 22:47:41.504    JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d9db680>
08    09/30/14 22:47:41.504    JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.2.232 <0x2d9db680>
08    09/30/14 22:47:41.505    JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=34:e2:fd:1e:1e:da <0x2d9db680>
02    09/30/14 22:47:45.103    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:47:47.233    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:48:09.372    ZWaveSerial::GetFrame 0x2b7daef0 timed out now 0 m_listGetFramePending 0 <0x2b7db680>
02    09/30/14 22:48:09.372    ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2b7db680>
02    09/30/14 22:48:09.373    ZWJob_PollNode::ReturnMessageNotReceived -end- job job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:5 node 19 didn\'t reply iOK 25 iBadTx 0 iNoReply 25 Abort returned m_iFrameID 0 <0x2b7db680>
02    09/30/14 22:48:09.373    ZWJob_PollNode:TongueollFailed job job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:5 node 19 battery 0 <0x2b7db680>
06    09/30/14 22:48:09.373    Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-comConfusederviceId:ZWaveNetwork1 variable: LastError was: Poll failed now: Poll failed #hooks: 0 upnp: 0 v:0xa147a8/NONE duplicate:1 <0x2b7db680>
04    09/30/14 22:48:09.374    <Job ID=\"865\" Name=\"pollnode #19 3 cmds\" Device=\"44\" Created=\"2014-09-30 22:47:45\" Started=\"2014-09-30 22:47:45\" Completed=\"2014-09-30 22:48:09\" Duration=\"24.273150000\" Runtime=\"24.272377000\" Status=\"Failed\" LastNote=\"\" Node=\"19\" NodeType=\"ZWaveMultiEmbedded\" NodeDescription=\"Family Room Side Lamp\"/> <0x2b7db680>
02    09/30/14 22:48:09.375    JobHandler:TongueurgeCompletedJobs purge job#865 :pollnode #19 dev:44 (0xb1ed80) N:19 P:100 S:2 pollnode #19 3 cmds status 2 <0x2b7db680>
50    09/30/14 22:48:20.110    luup_log:17: Received: unknowncommand 14 <0x2d5db680>
02    09/30/14 22:48:55.104    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:48:57.243    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:48:59.402    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
04    09/30/14 22:48:59.552    <Job ID=\"866\" Name=\"pollnode #19 3 cmds\" Device=\"44\" Created=\"2014-09-30 22:48:55\" Started=\"2014-09-30 22:48:55\" Completed=\"2014-09-30 22:48:59\" Duration=\"4.451047000\" Runtime=\"4.449414000\" Status=\"Successful\" LastNote=\"\" Node=\"19\" NodeType=\"ZWaveMultiEmbedded\" NodeDescription=\"Family Room Side Lamp\"/> <0x2b3db680>
50    09/30/14 22:49:20.110    luup_log:17: Received: unknowncommand 14 <0x2d5db680>
08    09/30/14 22:49:50.112    JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-comConfusederviceId:HomeAutomationGateway1 action: LogIpRequest <0x2d9db680>
08    09/30/14 22:49:50.112    JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-comConfusederviceId:HomeAutomationGateway1 <0x2d9db680>
08    09/30/14 22:49:50.112    JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2d9db680>
08    09/30/14 22:49:50.113    JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.2.225 <0x2d9db680>
08    09/30/14 22:49:50.113    JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=38:0f:4a:9a:bd:57 <0x2d9db680>
50    09/30/14 22:50:20.110    luup_log:17: Received: unknowncommand 14 <0x2d5db680>
02    09/30/14 22:50:25.103    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:50:27.232    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
02    09/30/14 22:50:29.373    ZW_Send_Data node 19 NO ROUTE (nil) <0x2b7db680>
04    09/30/14 22:50:29.502    <Job ID=\"867\" Name=\"pollnode #19 3 cmds\" Device=\"44\" Created=\"2014-09-30 22:50:25\" Started=\"2014-09-30 22:50:25\" Completed=\"2014-09-30 22:50:29\" Duration=\"4.401062000\" Runtime=\"4.399755000\" Status=\"Successful\" LastNote=\"\" Node=\"19\" NodeType=\"ZWaveMultiEmbedded\" NodeDescription=\"Family Room Side Lamp\"/>
